Author Topic: Does the advancer assembly from Honda include the springs?  (Read 1883 times)
Offline Scott S
« on: August 07, 2010, 05:39:24 PM »
 Looking at the parts diagram, part #7 is the advancer assembly. Honda SKU # 30220-323-005.
 If I order that part will it have the springs as well?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Fritz
Re: Does the advancer assembly from Honda include the springs?
« Reply #1 on: August 07, 2010, 06:04:20 PM »
Yes, it does include the springs.
Here's a picture of the part
1976 CB550F
Offline Scott S
« Reply #2 on: August 07, 2010, 06:27:00 PM »
 Excellent! I thought it did but that picture isn't very clear.
  I'm having a sticky throttle/hanging idle problem and I think it's the weights and/or springs (I've all but eliminated any carb issues).
 I'll call my local Honda dealer on Tuesday when they reopen and get one ordered.
'71 CB500 K0
'81 Yamaha XS650
Offline chickenman_26
    • Motorcycle Consumer News
« Reply #3 on: August 07, 2010, 06:46:11 PM »
I tried to order a new one for my '71 CB500 a few months ago and was told it was discontinued. If your weights are loose due to stretched springs, they can be tightened up enough to work properly by cutting off one half of the end loop on one side of each spring, then bending the remainder of the loop back into a circle.
Stu
MCN DTF
Offline Scott S
« Reply #4 on: August 07, 2010, 06:57:42 PM »
 Tried that already. Where did you try to order yours from?
'71 CB500 K0
'81 Yamaha XS650
« Reply #5 on: August 07, 2010, 07:20:46 PM »
Check that your advance is working properly, or not, with a timing light, before you start throwing parts and money at your problem.
Offline Scott S
« Reply #6 on: August 08, 2010, 03:38:12 AM »
 And if it's not working properly, I'll still need this part....right?
'71 CB500 K0
'81 Yamaha XS650
bollingball
« Reply #7 on: August 08, 2010, 06:19:53 AM »
Have you tried taking it apart and cleaning the pivot? Mine had been lubed by PO which attracted dirt they should be clean and dry springs off should move freely
Offline Scott S
« Reply #8 on: August 08, 2010, 06:44:59 PM »
 Yes, that has been done. Please see my newest thread about "idle hover". Help me out here!
'71 CB500 K0
'81 Yamaha XS650
« Reply #9 on: August 10, 2010, 07:16:45 AM »
American Honda
MCN DTF
