Author Topic: How important is mileage when buying a vintage CB?  (Read 9555 times)
delmar
« on: August 08, 2010, 01:29:09 PM »
Ive paid a guy in california $2500 bucks up front and he is going through some light restoration on a 76 cb550, hes gonna do the paint, carbs, cables, pods, test charging systems, change or clean any faulty connections, replace the drive chain and sprockets, bleed breaks and replace any pads or shoes and last but not least tires.
The bike is a 76 cb550 with 28,000 miles. He says as long as it idles low, and the compression is good, mileage doesnt matter. I will be paying this guy nearly 4 grand at the end of this for the bike.
My plan was to have a good working bike to make the learning curve a little easier on me.
Whats your thoughts on this deal? Am i being paranoid about the mileage?
im waiting on him to send me the compression test results.
P.S. im a newb :/
« Last Edit: August 15, 2010, 07:29:44 PM by delmar »
Re: How important is mileage when buying a bike?
« Reply #1 on: August 08, 2010, 01:58:53 PM »
First off, I would NEVER pay upfront for a deal like that.
Secondly, $4K is way too high for a 550 [unless it was in mint cond w/less than 5K mile].
Back to your original question: normally, milage is not the most important thing when buying a vintage bike as there are many factors to consider [original motor? was routine maint performed??]
If I were you, I would ask for a refund.
Good Luck.
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: August 08, 2010, 04:39:53 PM »
Good Luck.
+1 to all of that.
Offline shizzomynizzo
  • It's 5 o'clock somewhere
« Reply #3 on: August 08, 2010, 05:11:25 PM »
An original museum piece MIGHT bring that much.
Or a cafe that has been done VERY nicely w/some rare parts.
I've seen mint 550's with under 8k miles asking 3K.
+1 on the asking for a refund!
To answer your original question, these motors have been known to surpass 100k miles with proper maint.
« Last Edit: August 08, 2010, 05:16:28 PM by shizzomynizzo »
1974 CB550
1985 XLX Last of the IH
2001 Street Glide
delmar
« Reply #4 on: August 08, 2010, 07:07:54 PM »
Rad, thanks guys! Youve been a big help!
« Reply #5 on: August 08, 2010, 07:46:33 PM »
Mileage on the engine not so much a big deal if maintenanece kept up. Problem is sitting around is never good. High mileage stored in climate controlled garage in AZ may be better than low mileage is a storage shed in WI. Condensation occurs regardless and may wipe out the inside of a motor.
Also, mileage goes to wheel bearings, swingarm bushings, shockes and fork springs, other running gear. A high mileage cable may be in better shape than a low mileage cable that's been allowed to get rusty inside. It looks pristine but will cause all sorts of "feel" problems. Or a high mileage cable may be ready to break, even though it moves freely.
What you are doing sounds awful risky to me. For $4,000 if you're not getting the satisfaction of doing the work yourself, there are an awful lot of late model 21st century trechnology used bikes out there right now. Low mileage and low age.
But its only money, if thats the bike you want and can pay a pro for the work, swing batter.
« Last Edit: August 08, 2010, 07:48:41 PM by MCRider »
Offline Kframe
  • Life is good!
« Reply #6 on: August 08, 2010, 08:56:42 PM »
The above is good info, lack of use is hell on motorcycles.
The worst is when a seller/PO says he never rode much but ran it for ten minutes every month or so for several years.
Just makes for more condensation which is just murder over time.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
delmar
« Reply #7 on: August 08, 2010, 09:00:17 PM »
I just want a decent running bike i can use as my daily, and fix it up as it breaks down. Im really unsure where to begin and what a good bike would be to start with. I thought putting a big chunk of money in there would get me something quality and i could learn with a bit of a handicap having someone help me out at first. But maybe im looking for something too new on a vintage bike? I dont know enough to be buying one of these on my own, and dont know anyone.. or rather dont have any friends who know about these bikes.
Offline Kframe
  • Life is good!
« Reply #8 on: August 08, 2010, 09:09:00 PM »
Well this is a 'vintage' SOHC site, so you're going to get advice/suggestions that are biased toward these bikes and other "standards".
As MC said, $4K can buy a lot of bike, even something from 2000 and newer.  Especially given the economy, you can get $6K bikes for $4K.
If you like cruisers, there are many Honda Shadow 750-1100's in that price range, also Yamaha Stars come in 650-1600cc versions.
If you want a "standard" (upright seating, relaxed hand positions, feet below hips) you could look at a Triumph Bonneville from 2001+.
Some people really get a blast out of dual sport motorcycles, often single cylinder in the 400-650cc range.
They're mostly road bikes but can handle gravel roads and dirt trails with aplomb.
Do some exploring on the 'net, plug $4K into ebay or cycletrader and see what pops up and tickles your fancy.
These older SOHC's are a ton of fun, but do require on-going TLC and could frustrate a person that just wants a reliable "fill it and ride it" kind of bike.
-K
1986 Honda Helix
« Reply #9 on: August 08, 2010, 09:10:24 PM »
Worry more about the kind of miles.. I would take a 750 with 50K "used for mostly touring"..over a 15K "only around town bike"
Offline Kframe
  • Life is good!
« Reply #10 on: August 08, 2010, 09:12:23 PM »
Oh, and if you go with your first plan and pay someone $1500 more to fix up a bike that cost $2500, you don't end up with a $4000 bike, more like a $2000-2500 bike.
-K
1986 Honda Helix
Offline Shenanigans
  • Right turn?
« Reply #11 on: August 08, 2010, 09:16:26 PM »
You should be able to find or buy a pristine CB for 3K.
4K cash around PHX during the "winter" months should be able to buy a LOT of bike. Sounds like your looking for something thats a bit more hop on and go. You might want to do a whole lot more research on finding what bike you want before putting down that kind of cash. That way you can figure out exactly what kind of bike you are looking for.
Offline Kframe
  • Life is good!
« Reply #12 on: August 08, 2010, 09:20:15 PM »
Y'know, another option is to just buy a $3K ready-to-go bike of whatever variety you want, and then pick up a $250-$700 CB at some point and pick away at getting it going.
That way you can have your reliable daily-runner and also satisfy your desire to learn about bikes and tinker.
More bikes=better, right?
 ;) :D ;D
-K
1986 Honda Helix
Offline kck3
« Reply #13 on: August 08, 2010, 09:37:58 PM »
What's the name of the guy or shop  doing the resto?  A member on  here might know of him/them and let you know about their work.  It might be your market, but around here $2500 gets you into  a pretty  decent bike that doesn't need $1500 more of work.  Just be careful, hope you get a badass bike.
« Reply #14 on: August 08, 2010, 11:56:35 PM »
That's true for the 750 but not the 550. Particularly the early models pre-77 that do not have the rocker shaft wear fix.
Certainly any engine is going to need routine maintenance and care rather than neglect and/or abuse.
Offline Lars
« Reply #15 on: August 09, 2010, 12:51:39 AM »
I would not worry too much about the miles. Your total cost will not get you a cheap bike, but the CB 550 is a very goodlooking bike and it handles very well! Easy to ride and power is good. On eBay lots of this model is to find for a nice price. Sometimes ready to run, sometimes a little work needed but still cheaper....
New mufflers on this one and off you go:  http://cgi.ebay.com/ebaymotors/1974-Honda-CB-550-CB550-Low-Miles-Ship-/120606677408?pt=US_motorcycles
Lars
...if you got the ability to act...
Offline Spanner 1
« Reply #16 on: August 09, 2010, 06:38:51 AM »
I think this thread is a joke by the OP.....4k on a 550 with 28,000 miles?, " you out you mind"...... ;)
Offline climbingaz
« Reply #17 on: August 09, 2010, 10:29:25 AM »
[/quote]
[/quote]
Hey Delmar,
I'm by no means an expert compared to the guys here on the board, but I'm in Tempe if you want any advice from a local guy.  I'm bringing back to life a '78 750k that I bought for $100.
Good luck,
Shawn
delmar
« Reply #18 on: August 09, 2010, 08:00:21 PM »
His name is jeremy and he runs vintagehondacb.com
Still figuring it out! >_<
Offline bluezboy
« Reply #19 on: August 09, 2010, 08:29:58 PM »
ebay, ebay, ebay! There's where I scored my first bike, a 73' 750 that is in great shape and was easier to learn to ride than i imagined. I paid 2200 for it and will put a little more into it. 4000 is too much for a 55o unless that bike is a show ready bike. Good luck, now go get your money back
« Last Edit: August 17, 2010, 09:07:00 AM by bluezboy »
Offline pdxPope
  • Hit Shit, Hat Shat, Hut Shut,
« Reply #20 on: August 09, 2010, 08:32:30 PM »
Wow. You are a trusting soul, aren't you...
http://phoenix.craigslist.org/nph/mcy/1889884347.html
http://phoenix.craigslist.org/evl/mcy/1889746173.html
http://phoenix.craigslist.org/nph/mcy/1889489506.html
http://phoenix.craigslist.org/nph/mcy/1888856338.html
http://phoenix.craigslist.org/wvl/mcy/1888213810.html
http://phoenix.craigslist.org/nph/mcy/1888201002.html
(All from today's Phoenix Craigslist.) Any of these would make a better first bike than a CB550. I would recommend either of the 250 Ninjas as first choice, with the 400 Maxim as 2nd.
-JP
The flowers say "Let's go shopping together..."
While the unicorn whispers "...for adult toys."
« Reply #21 on: August 09, 2010, 10:42:34 PM »
i dont get so long as it idles low?ill wind mine right down and its yours for 6k.
delmar
Re: How important is mileage when buying a vintage CB?
« Reply #22 on: August 15, 2010, 07:40:21 PM »
Right? He says he did a simple tune-up and as long as it idles low the compression is good. but he wont give me exact PSI readings.
Offline Grnrngr
« Reply #23 on: August 15, 2010, 07:46:27 PM »
FWIW, the Virago I'm currently riding has 16k on it and burns oil, my other Virago with 22+k doesn't...mileage doesn't matter as much as previous care.
'72 CB750-K2 "PopCycle"
'73 CB750-K2 "Barney"
'77 CB750A
'83 Virago 500 (red)
'83 Virago 500 (black)
delmar
« Reply #24 on: August 15, 2010, 08:06:16 PM »
I thought buying a partially restored CB would be the best way for me to learn how to work on these bikes as a newb, but as a newb you can really be taken advantage of. Ive been reading dansmc.com and reading a clymer for a 76 CB550, but maybe this is the wrong way to go about it? I was looking at the faq's and i just dont know how you immerse yourself into the mechanical aspect if youve never really been around it.
Thanks for all the help, guys and gals!
