Author Topic: What now? Idle "hover"  (Read 17133 times)
Offline Scott S
Re: What now? Idle "hover"
« Reply #75 on: September 17, 2010, 11:47:57 AM »
 Set the floats on the two inner carbs, updated the rubber on the manifolds and put her back together.
 I checked the synch with vacuum gauges and it was so damn close I left it alone.The #1 cylinder was pulling more vacuum than the other three by about the thickness of the pointer tip on the needle. Close enough for me.
 She's no longer hanging up. I have a slight bit of the "slow to return to idle" thing going on, but only when the bike is static. I've fiddled with the mixture screws a bit, and it helped. I plan on riding it for a while and make very minor adjustments as needed. It doesn't seem to do it as bad or at all when riding/under load and coming back to idle.
 Even though I thought the floats were correct, it turns out that something that simple made me chase my tail for weeks. It sucks R&R'ing the carbs, but it sucks even worse not being able to ride!
 To GregK: According to the specs on this site, the CB550 carbs should be set at 22mm as well.
  http://www.sohc4.net/index.php?q=content/cb500550-carb-id-and-specs
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline Old Scrambler
« Reply #76 on: September 17, 2010, 01:07:03 PM »
Great Job Scott................your trouble is a teaching lesson..........and thanks 2-Tired for the air-flow to fuel-jet explanation in relationship to the carb slide and piston action.  This lesson also points out that replacement parts require significant adjustments from original spec.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
