Author Topic: balance tube?  (Read 1210 times)
Offline famoussas1
balance tube?
« on: August 08, 2010, 07:19:29 PM »
saw a 79 750 k on craigslist for $500, in WI, balance tube leaks? what is that exactly?
Offline Kframe
  • Life is good!
Re: balance tube?
« Reply #1 on: August 08, 2010, 07:23:31 PM »
That generally refers to a rubber or plastic tube that is underneath the tank and connects both sides.
It allows fuel on the right side to get to the petcock on the left.
Leaking could be a cracked tube (easy to fix), or a crack in the metal barb/nipple on either side of the tank (a pain to fix).
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Offline crazypj
  • I'm brill, me
Re: balance tube?
« Reply #2 on: August 08, 2010, 07:40:59 PM »
Don't think that has a tank balance pipe?
 More likely it's exhaust balance tube, probably behind gearbox/under swing arm pivot
Offline famoussas1
Re: balance tube?
« Reply #3 on: August 08, 2010, 07:42:47 PM »
thanks..i know nothing of 750's. saw the price and i want a 750, but not sure what the tube actually was.  maybe ill check it out if its still around next weekend and i am in that area.
Re: balance tube?
« Reply #4 on: August 08, 2010, 07:52:54 PM »
Yeah while kframe is correct that is a balance tube on many models, don't think so on the 750.
FYI You're looking at a DOHC model that's why your post was moved to other bikes. Not a SOHC. CB750 SOHC have no balance tubes of any kind, fuel or exhaust.  IF that leaks its from rust and where theres a hole theres another one hiding.
More likely a leaky exhaust balance tube as per Crazy.
Offline Alan F.
Re: balance tube?
« Reply #5 on: August 08, 2010, 07:55:31 PM »
My first instinct was the air forks' balance tube...Honda was big into air caps with a crossover tube at the top of the forks in those days.
Alan
Offline Kframe
  • Life is good!
Re: balance tube?
« Reply #6 on: August 08, 2010, 08:00:28 PM »
Nice catch.  I was just throwing out a guess.
I agree with the assessment on rust, there is NEVER just one spot or hole.
-K
1986 Honda Helix
