Author Topic: O-Ring Chain damage CB550  (Read 2369 times)
Bwatson
« on: August 08, 2010, 09:13:05 PM »
Hi, I have a bad oil leak on my cb550, its been leaking since I bought the bike. I replaced the oil pan seal, oil pump seals and shift shaft seal thinking I was fixing my leak, but I knew shortly after running the bike nothing fixed it. After looking more into it I found that the o-ring chain that was on the bike has worn into the casing and rubber plug and thats where the leak is.
My question is how do I fix this once I get the right chain on this thing. Can I replace the plug/seal thing thats worn? If so whats involved in changing it? Where can I get a new plug/seal? Thanks.
Heres a pic after some cleaning.
and heres one of the bike because shes awesome
Offline TedH
Re: O-Ring Chain damage CB550
« Reply #1 on: August 08, 2010, 09:19:29 PM »
A buddy 'Peterbylt' has a '75 CB550F with a similar issue.  He found the o-ring chain ran too close to his case.  He replaced the wide o-ring chain with a non-o-ring chain.  However, his solution for the leaking case was to first dry the surface/drain the case.  Then, he applied 'marine tex' to the damaged case area.  Marine Tex is often used to repair damaged hulls on boats and I've also used it to repair motorcycle crankcase damage.  It hardens and is impervious to gas and oil.
Cycle Ownership:
Past:
90cc 2-cycle Rockford (mid-70's)
85 CB450SC Nighthawk
75 CB750K
85 VF1100 Magna
77 CB750F
95 VF750 Magna
76 CB550F
01 FXDXT
80 XS850SG
78 CB550K
Present:
75 CB550F
80 XS850LG
Bwatson
« Reply #2 on: August 08, 2010, 09:27:09 PM »
I was thinking something like that (JB Weld kinda stuff), but if its not much work I would like to swap out the plug.
Offline Kframe
  • Life is good!
« Reply #3 on: August 08, 2010, 09:30:07 PM »
I think the cases need to be split to replace that plug or the countershaft o-ring seal.
-K
2007 Triumph Bonneville T100, ARK'd, Pods, TOR's, Napoleon's, Innovate G5 Air/Fuel Gauge, Ignition Relocation by D9, Stebel Nautilus, Avon Roadriders
1984 Honda Shadow VT700c, Stock
1974 Honda CB550K, In rehab
1986 Honda Helix
Bwatson
« Reply #4 on: August 08, 2010, 09:40:20 PM »
-K
yuck.
Offline Kframe
  • Life is good!
« Reply #5 on: August 08, 2010, 09:51:32 PM »
I know.
If it was me, I'd try to squirt some sort of sealer in around that plug with a syringe and needle, of course, you have to have access to those.  I don't know if an insulin syringe's needle would be stiff enough to get in there.
If you know a nurse or a doctor you might be able to tell them what you're doing and get some 'samples'.
I honestly don't know if it'd work, but dang man I'd try anything to avoid splitting the cases.
Others here will know more about this.
I think that rubber plug is part number 82 on the end of the mainshaft part 11 in the "Transmission - Kickstarter" microfiche at Bikebandit.
http://www.bikebandit.com/houseofmotorcycles/1974-honda-motorcycle-cb550/o/m9230
-K
1986 Honda Helix
Bwatson
« Reply #6 on: August 08, 2010, 10:22:42 PM »
-K
Looks like the right plug, but doesn't look available. To me it looks like if I could get the old one out I could pop a new one in, but I have no idea, I couldn't find any post with the same issue.
Offline Kframe
  • Life is good!
« Reply #7 on: August 08, 2010, 10:26:32 PM »
There's been posts about this before.
Do a search for 'case damage' or 'o-ring chain damage' or something.
It's in there somewhere.
Also, check www.servicehonda.com for availability, I've found they have some items that BB does not have.
-K
1986 Honda Helix
