Author Topic: The SOHC4 Nugget Thread  (Read 40513 times)
« on: August 09, 2010, 02:25:30 PM »
Kinda like the Babe thread without the pictures, but more like Man-Laws.
Thoughts and Ideas we SOHC4'ers need to know and should live by.
Post your best (or a few) of your quick Nuggets of Wisdom, so that newbies can be new no longer, and old dogs might learn new tricks.
#1 Folded cardboard helps keep front caliper pads apart when front wheel is off.
#2 Auto windshield washer tubing makes good, cheap, temp carb overflow tubing.
Re: The SOHC4 Nugget Thread
« Reply #1 on: August 09, 2010, 02:33:02 PM »
#3 Simple green cleans most parts, well.
Markcb750
« Reply #2 on: August 09, 2010, 02:36:12 PM »
Mag wheel cleaner is great for cleaning the motor, spray it on rinse it off.
I use the turtle wax brand.
Offline eshumaker
« Reply #3 on: August 09, 2010, 02:57:51 PM »
NoobMove: Con rods, then cases. Unless you like practice with TripleBond...
1976 CB750 (basket case in progress)
1979 GL1000 Goldwing (runner)
1983 CB750 Nighthawk (basket case)
2004 Yamaha R6 (commuter)
Offline cookindaddy
  • I sure love this bike!
« Reply #4 on: August 09, 2010, 03:03:42 PM »
Read the manual, it's pretty good.
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
Offline Alan F.
« Reply #5 on: August 09, 2010, 06:43:42 PM »
Spend more time mastering the SEARCH function than you spend in the 'inspiration gallery'....but less time than you spend viewing the Babe Thread.
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: August 10, 2010, 08:40:46 AM »
If your bike is running poorly do a COMPLETE tune-up first.  Then, and only then, if it's still not running right come here and ask questions.
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: August 10, 2010, 08:43:55 AM »
If you ever plan on parking your bike on anything other than cold asphalt or concrete, keep a small piece of plywood or a section of old license plate under your seat to put the end of your kick-stand on.
Offline vanaman
« Reply #8 on: August 10, 2010, 03:50:43 PM »
or the nifty little disc they handed out a the msf course works great.
78 cb750f
97 VW Jetta GLX
98 Cabrio 1.8t
Offline Nikkisixx
« Reply #9 on: August 10, 2010, 07:23:40 PM »
Is the ignition on and does it have fuel (check the simple things first)?
Manufactures are cheap baztards, they don't put parts on just for fun (you probably need that)
When working on a motorcycle, never be in a hurry to go for a ride.  While riding a perfectly tuned motorcycle, never be in a hurry to get home.
Offline Skonnie Boy
  • Cold cock
  • Life is not like a box of chocolates.
« Reply #10 on: August 10, 2010, 07:37:30 PM »
Always blame the PO in public, but never forget your mistakes in private.
"Yeah, I'm hip about time. But I just gotta go."
Offline Alan F.
« Reply #11 on: August 11, 2010, 09:40:03 AM »
It always helps to have another bike to ride so that you won't cut corners on your project bike.
Offline Gordon
  • 750K1, 550K2
« Reply #12 on: August 11, 2010, 10:25:22 AM »
Don't kick-start your bike to impress onlookers unless you're positive you can start it by the third kick.
« Reply #13 on: August 11, 2010, 10:43:31 AM »
playing with your idle set screw more than once at a stoplight doesnt make you more cool.
great nuggets guys...keep 'em coming!  8)
Offline Gordon
  • 750K1, 550K2
« Reply #14 on: August 11, 2010, 10:52:54 AM »
When removing parts from your bike to work on it, whenever possible immediately put all nuts and bolts back on the bolts or in the holes they came out of.  This eliminates the guess-n-check procedure otherwise required to figure out where they're supposed to go after you've had several beers and are attempting to put things back together.
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: August 11, 2010, 10:53:20 AM »
Never attempt to put your bike back together after having several beers. 8)
« Reply #16 on: August 11, 2010, 10:56:50 AM »
Never squeeze the front brake when your front wheel is off due to a puncture and you are in the middle of nowhere with no way to push the brake piston back in ::)
Dont forget to hook up the oil return line between engine and oil tank and dont ride off after an engine rebuild with this disconnected.
Offline Gman
« Reply #17 on: August 11, 2010, 10:59:08 AM »
#1 - It helps to have a bike to go for a ride.
#2 - If looking for a bike on C-list (see #1), don't wait to call if you see "the one".  It will be gone (within 2 hours).
#3 - Go ahead and ask me how I know.
'76 CB550K
Stock airbox, MotoGPWerks 4-1, HondaMan ignition, Lesters
« Reply #18 on: August 11, 2010, 11:02:17 AM »
Portable sidestand discs are good to have. I had a disc welded to the bottom of mine. Removed enough material from the stand foot first to offset the thickness of the disc.
Offline tbpmusic
« Reply #19 on: August 11, 2010, 11:09:20 AM »
That's beautiful welding !!
Obviously I didn't do it.....
Bill Lane
« Reply #20 on: August 11, 2010, 11:21:39 AM »
Nor I. Saldana Racing Products: Brownsburg IN.  High end aluminum frames, racing tanks and radiators...or low end junk like mine. Same welder.
Offline HedNut
  • Underwater Basket Weaving
« Reply #21 on: August 11, 2010, 11:27:25 AM »
Wow...tha weld is amazing!...if that wasn't a ROBOT...the person who laid that bead deserves a GOLD star FOR SURE! nice!
« Reply #22 on: August 11, 2010, 11:28:46 AM »
Just Bob. Bob the Welder.  ;D
Offline HedNut
« Reply #23 on: August 11, 2010, 11:33:28 AM »
BOB THE WELDER! That's excellent!.... BOB THE WELDMASTER-BEADBURNER!!!  truely awesome!
Offline Brown Bomber
« Reply #24 on: August 11, 2010, 11:43:45 AM »
WD-40 gets rid of oxidation on unpainted aluminum parts. Also breaks down grease, oil, and tar so it can be wiped off easily. WD-40 is cheaper than those highly toxic degreasers, smells better, and doesn't burn your skin. Once you see how easily it breaks down grease and oil, you'll understand why it is a bad idea to use it as a cable lube.
Keep the Shiny side up!
1987 ZG1000 "King Crimson"
1972 CB750K2 "Stout"
1976 CB500T "Witch's Promise"
1973 CL450K5 Cafe Project
        Vito Corleone
