So.. I popped a leak two days ago.
It is not really significant right now, since it only leaks while running... but I intend to fix it...
It appears to be coming from the left side of my breather cover on the very top of my top end.
So.. my question is this:
Can I safely assume it is the breather cover gasket?
that is: GASKET, BTHR CVR 12329-323-000
Or
#3and that replacement of such will fix it?
I have NO comorbidities whatsoever, and no other leaks.
I ask because I love to have replacement gaskets on hand before I open things up... soas to only do it once
![Smiley :)](http://forums.sohc4.net/Smileys/default/smiley.gif)
Also.. is this a common leak point? I searched briefly, but most threads are about o-rings...
thank you all..
c
