Don't worry this job is pretty easy. First off you'll need to remove the kick start lever and the chrome cover. Then run both the adjusters all the in, to make the cable slack. Then I remove the nut that holds the arm on the lifter plate shaft, then remove the cable end from the arm. Then at the the lever just line up the slot in the adjuster, lock nut, and lever. Then just slide the cable out of the lever. Baiscly the installation is the reverse of the removal, then just adjust the clutch and cable as per the manual, and your all set to go.
Here is how I adjust the clutch and cable (if you want to know). I loosen the lock nut on the lifter shaft and run it in till I feel it bottom out, then I back it off a quarter turn and lock it down. Then I like to take just a small amount of slack out of the cable with the bottom adjuster (my personal preference). Then I fine tune the rest of the adjustment at the lever.
Good Luck, hope this helps.
Travis
