Kman, he posted that 5 years ago. What set up are you currently running on your bike? Pics? What issues are you exactly having? Welcome to the site and I am just north of you near Milwaukee .
Thanks for getting back to me so quickly guys,
Setup: believe stock jets so 100 main and 40 pilot. No idea what oil was in the bike but topped it off with 20W-50 motorcycle oil. 93 oct gas. Battery was at 11.88 this morning, at 2,000rpm it went to 12.56. Idled at about 1000
bike sounded great when I bought it last fall. Thought I emptied all the gas out for the winter. Never really took it for a spin until a month ago. Started up fine after a carb cleaning and a trickle charge. Would take it for spins around my Chicago neighborhood and it would die out after 40 min, at this point it would be hard to shift in and out of gears and would not start with electric start or kick start. I thought it was the battery so I would walk it home and trickle charge it. Next day it started fine, rode it for 40 min and same stall out, but this time I got it home and didn't trickle it and came back to it an hour later and it started right up with both electric and kick. Took a chance and attempted to drive it to work on a ten minute highway trip. The trip started smoothly but I felt the bike loosing power and as I hit my off ramp the bike was completely shut down. i caught a faint smell of something burning and the gear shifter was really tough to move. I waited about ten minutes and was able to electric start the bike and get to work. I believe it is a overheating issue because if I let the bike chill for ten minutes it starts back up. Same thing happened on my trip back home, happened faster though and before my exit. Is it possible that the rectifier/regulated is reacting to the heat poorly?
Update: attached are picture of the bike and the spark plugs, looks like I'm running rich. But as I put the cap back on it snapped loose and is not attached to the wire anymore. Seemed very unstable because it came off so easily. Obviously this could be a factor as well.
Thanks
Karl
