Author Topic: trying to buid a CR 750 look alike  (Read 25833 times)
Offline Roach Carver
Re: trying to buid a CR 750 look alike
« Reply #125 on: January 01, 2013, 07:58:02 PM »
 Nice work!
Offline silvercr750
  • building a modern CR750
  • how i started
« Reply #126 on: January 02, 2013, 06:21:28 AM »
hi guys,
here you can see the stator inside the rotor.
It only just fits inside the fairing.
The cover is next in line.
This will also be a one of a kind.
  • Moderator
« Reply #127 on: January 02, 2013, 07:48:39 AM »
Very neat.  8)
Offline kos
    • m3racing.com
« Reply #128 on: January 02, 2013, 02:09:00 PM »
Any updates?
I like what I see so far.
Would like to learn more details about exactly how the exhaust pipe fits into the exhaust port. I know it's held tight against the head with springs, but why not use the original flange that was on the pipe?
220...221, whatever it takes.
Offline ivanhoew
« Reply #129 on: January 03, 2013, 12:26:42 AM »
inspiring stuff .
just do it .
Offline silvercr750
  • how i started
« Reply #130 on: January 03, 2013, 06:40:33 AM »
Hi there KOS,
I've modyfied the exhaust pipe because of our expirience in racing with a 250 Honda.
For removing the exhaust after every training and race it is much easier to just remove the springs.
And now that 1 tread of M8 is almost gone in the cilinderhead I wanted to mount the flange for ones and for all.
It doesn't matter howmany times the exhaust must be removed the tread will always be oke.
This way, if any exhaust must be removed I only need to pull 2 springs and it's gone.
If all four exhausts must be removed only 8 springs and 2 bolts have to be removed.
I've used the original flange to fit in the exhaust port. I've just cut them of the exhaustpipes.
Then a double flange was made to fit on both sides over the original pipe.
the lose double flanges
Is this what you asked?
Regards
Offline silvercr750
  • how i started
« Reply #131 on: January 03, 2013, 06:47:41 AM »
If also found an older pic with a little drawing.
Offline silvercr750
  • how i started
« Reply #132 on: January 06, 2013, 01:54:45 PM »
As the generator is under construction I picked up the carburator's for cleaning.
And the frontbrake is also finished for use.
But the generator is one step further.
these are the parts needed for consturction
Offline Blitzburgh207
« Reply #133 on: January 17, 2013, 08:02:25 PM »
Gotta subscribe to this...awesome.
1978 CB750 K8
Offline silvercr750
  • how i started
« Reply #134 on: February 03, 2013, 09:53:10 AM »
Hi there,
A lot of work has been done on te generator-parts.
It´s all millimeter-work but it had to be done so it all fits inside.
Here you see the parts apart.
And here you will see the next job to be done.
« Last Edit: February 10, 2013, 05:03:43 AM by silvercr750 »
Offline silvercr750
  • how i started
« Reply #135 on: February 06, 2013, 12:17:54 PM »
steady going on with the generator.
Cover is on the groundplate.
Now a nice form has to be cut out
Offline jerry h
« Reply #136 on: February 08, 2013, 09:23:58 PM »
I love seeing parts (bike) being made.... very inspirational -  beautiful work.   Can't wait to see what's next. ;D
Offline silvercr750
  • how i started
« Reply #137 on: February 10, 2013, 05:02:38 AM »
thanks Jerry,
next step is to make a form in the cover.
This is how it's now.
Hope it will fit inside the fairing.
