Author Topic: Cb400F stumble  (Read 1269 times)
Offline MADCB400F
  • My 74 CB750
Cb400F stumble
« on: August 19, 2010, 03:44:54 PM »
Hi all, need some tuner help, I have a CB400F with a 466 kit, webcam stage II. The carbs have 98 mains, 38 pilots, air screws about 1 1/2 out. They have been synced on bike, new plugs , timming correct(electronic), vales correct. I have a stumble between 1 and 3000 rpm. Need advice to correct. Thank you.
Offline jessezm
  • '77 cb400f cafe build
  • Always wrenching...
Re: Cb400F stumble
« Reply #1 on: August 19, 2010, 03:47:30 PM »
Try raising the needles one position maybe?  You're running pods, I presume?  I'm watching closely, as I have almost the same set up but haven't fired her up yet.  Have you checked to make sure your advance mechanism is functioning properly?
Offline MADCB400F
  • My 74 CB750
Re: Cb400F stumble
« Reply #2 on: August 19, 2010, 03:51:09 PM »
Yes running pods, will try the needle, thanks
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
Re: Cb400F stumble
« Reply #3 on: August 19, 2010, 03:53:53 PM »
Try stacks instead of pods.
1 to 3 grand on a 400 is usually mostly idle circuit, really. Needle position doesn't really affect this.
I recently had some issues with an XS400 that could not be run with pods. Didn't matter what the jetting was.
I have seen pods work on your particular carbs fine, though.
What do your plugs look like?
Try the airscrews at 3/4 out.
No.
Offline jessezm
Re: Cb400F stumble
« Reply #4 on: August 19, 2010, 03:57:08 PM »
With the open exhaust (I'm also guessing that's yours in your avatar picture?), I wonder if the pilot jet might need to be a little bigger?  I was told by Rick Denoon that the trick to running pods on the 400 is dropping the pilot to #38 and raising the needle one notch, but with all that extra breathing i guess I wonder if it's starving a bit for fuel.  I'd try the needles first (even though they are a pain to change!), then maybe turn in the mixture screws another quarter turn, and if that doesn't work, maybe think about bigger pilot jets.  Just guessing...  Plug chops would probably tell you more of course.
Offline jessezm
Re: Cb400F stumble
« Reply #5 on: August 19, 2010, 03:58:41 PM »
Ah, and mlinder seems to have some ideas--maybe go further in with the mixture screws as he suggested.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: Cb400F stumble
« Reply #6 on: August 19, 2010, 03:59:11 PM »
That's for 1/4 to 3/4 roll-on richness, not 0 to 1/4 roll on, which is about all you should be at below 3 grand on these little fellas.
No.
Offline Tim2005
Re: Cb400F stumble
« Reply #7 on: August 19, 2010, 04:12:36 PM »
I'd do a full throttle plug chop first, 98 mains are huge, with pods on my 460 I was running 85s. When you're sure the top end is correct work down through the rev range with jetting.
Also you could try advancing the ignition 5 degrees, should help too.
Offline MADCB400F
  • My 74 CB750
Re: Cb400F stumble
« Reply #8 on: August 20, 2010, 07:19:38 AM »
Here is what the plugs look like so far
Offline MADCB400F
  • My 74 CB750
Re: Cb400F stumble
« Reply #9 on: August 20, 2010, 07:28:40 AM »
Since the plugs seem to look ok, does the slow jet control the gas at the rpms I am stumbling at, if so would it be better to try a 40 slow jet or adjust the needle, man pulling these carbs apart is a real pain in the @#$, thanks
Offline jessezm
Re: Cb400F stumble
« Reply #10 on: August 20, 2010, 07:31:23 AM »
Did you try turning the mixture screws to 3/4 out instead of 1 1/2 as you had them?  I'd give that a shot before pulling the carbs to change out the pilot jets.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: Cb400F stumble
« Reply #11 on: August 20, 2010, 08:33:02 AM »
You say you have an electronic ignition (which one?), so if it's working correctly, you aren't even in advance yet when this is stumbling.
Please try 3/4 out turn on your airscrews.
No.
Offline MADCB400F
  • My 74 CB750
Re: Cb400F stumble
« Reply #12 on: August 20, 2010, 09:06:39 AM »
Thanks all, so far this morning, I double checked the valves, readjusted a couple, advanced the timming about 1-2 degrees (Dyna) it is working fine. Resynced the carbs. Set the air screws to one turn out, anything before or after that makes the stumble worse.
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
Re: Cb400F stumble
« Reply #13 on: August 20, 2010, 09:47:44 AM »
So does that mean it's still stumbling, or not?
Which dyna?
No.
Offline MADCB400F
  • My 74 CB750
Re: Cb400F stumble
« Reply #14 on: August 20, 2010, 12:37:51 PM »
It is the Dyna S, yes it is still stumbling, I also tried using a 40 pilot today and that seemed to be alittle worse even after trying diffrent settings on the air screws.
Offline Rick4004
Re: Cb400F stumble
« Reply #15 on: August 29, 2010, 09:15:55 AM »
Try turning the choke on a little bit. Does that make the stumble better or worst. Better means you are lean, worst means you are rich.
Does the stumble get better or worst as the engine heats up. Better means you are lean, worst means you are rich.
Check the float levels, that can have a big impact.
You don't say if you are running the stock coils, but if you are I would greatly recommend an upgrade to some Dyna's or equiv.
The stage 2 cam might be a problem too. Haven't had any experience with that particular cam, but generally speaking the wilder the cam the harder it is to get the tuning right thru the whole rev band.
Rick Denoon
