Author Topic: alcohol carburetor  (Read 1998 times)
Mark Karlsson
alcohol carburetor
« on: August 20, 2010, 11:29:44 pm »
Hello.
I have a single overhead cam Honda 750 drag bike, turbocharged and I'm thinking about running it on methanol.  I currently use an SU carburetor.
Does anybody know of a carburetor I can use that would have adequate flow to be used with alcohol (methanol)?
9.10 at 146 MPH  -- currently looking for more horsepower!
Thanks.
Mark Karlsson
  • Moderator
Re: alcohol carburetor
« Reply #1 on: August 21, 2010, 02:18:23 am »
Welcome Mark, back in the day, most of the top supercharged bikes in the UK ran SUs.
As a starting point, just double the main jet, it's very difficult to be to rich on methanol but being to weak will end in the same results as being weak on petrol.
Make sure there are no plastic or rubber components in the carb as methanol can damage some of these components.
How about some pictures and what is your location?
Sam. ;)
« Last Edit: August 23, 2010, 02:46:08 am by SamCB750A »
Offline johnny_from_bel
  • Member #158
« Reply #2 on: August 21, 2010, 02:30:34 am »
Dubbeling the Jet size is obout correct.
Please not that the following is purely theoretical. I have never done it myself.
Use your own jugement on this !!
Stoichiometric air-fuel ratio of
Petrol is 14.7  1
Ethanol is 9:1
Methnanol is 6.4 : 1
Wiht that you can calculate the jet size
Sp = ratio for petrol
Se = ratio for ethanol
Js  = Current Jet Size
Jn  = New Jet size
Jn=(Sp/Se)*Js
Eg for Ethanol
14.7/9*current Jet size.
Hope this helps a bit.
Offline kos
    • m3racing.com
« Reply #3 on: August 22, 2010, 02:33:18 pm »
Hello.
Thanks.
Mark Karlsson
Mark
Order up a set from me and they will have all jetting changed over to run alcohol. CR Specials. 29, 31, 33 & 35mm.
Mark @
KOS
220...221, whatever it takes.
  • Moderator
« Reply #4 on: August 22, 2010, 02:37:08 pm »
It would have to be a big one Mark, he only wants 1.
Sam. ;)
  • Moderator
« Reply #5 on: August 24, 2010, 06:01:13 am »
I guess the thread starter wasn't really bothered about an answer ;D ;D ;D ;D
Anyway, I did a bit of digging and if he deceides to go the whole hog, he can expect it to run mid 7s :o :o :o
http://forums.dragbike.com/forum_posts.asp?TID=14706&PID=191867#191867
Thanks Big Jay. 8)
Sam. ;)
