Author Topic: Leaky Oil Pressure Sending Unit  (Read 2629 times)
Offline 736cc
« on: August 23, 2010, 02:19:52 PM »
Anybody ever have a problem w/ a leaky oil pressure sending unit ABOVE the starer motor? Mine is leaking all of a sudden pretty good. Pain in the balls to get to, maybe remove it and teflon tape the threads? Not sure if that'll fix it, maybe its leaking out the top or something? Who knows the trick to remove and fix ez?
Offline Duke McDukiedook
  • Space Force 6 Star General
Re: Leaky Oil Pressure Sending Unit
« Reply #1 on: August 23, 2010, 02:21:11 PM »
I don't know but if someone has a good quick fix I would like to know- mine is leaking pretty well itself.
« Reply #2 on: August 23, 2010, 05:57:57 PM »
They can fail in that manner. Good idea to replace the sender if it is the source of leak before it fails completely and sprays your oil out onto the road or your pants or worse, your rear tire.
David
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #3 on: August 23, 2010, 06:25:30 PM »
David beat me to it, ....what he said happened to me, but caught it before it was too late.
I think the sender is a fairly common unit,
 Matt.
Gallery at:
69modelj
« Reply #4 on: August 23, 2010, 07:17:32 PM »
About 36.00 (ouch) iirc. Don't lose the very small nut that holds the wire on. It doesn't come with the new unit and can get away from you during assembly/dis assembly quite easily. Part number has been superceeded several times, but they are still available.
Offline axehole54
  • Who the heck decided to call me a
  • #169 North
« Reply #5 on: August 23, 2010, 07:41:24 PM »
Anyone know if those are pipe  thread? If they are i bet a general motors sender would work they are just a ground switch are they not?
73 750k, 78 750k, 69 c10, 87 r1500 (c10), 94 fzr1000
« Reply #6 on: August 23, 2010, 09:54:10 PM »
If you have a gauge then no, if it is just driving an idiot light then yes, IF the trigger psi is the same, then the GM unit (aftermarket) would work fine.
rcavax
« Reply #7 on: October 08, 2011, 04:49:08 AM »
I just replaced my Sender unit with one from NAPA Auto Parts. The thread is a standard pipe thread and you need a unit that activates at about 6 psi.  The cost was about $7. It works fine. I did have to change the attachment spade, but that was easy. I just drilled a 1/8" hole in the spade and used a 3mm bolt to attach the wire. This is on a CB 550
« Reply #8 on: October 08, 2011, 09:45:52 PM »
ive used generic ones no trouble,the actual pressure spec isnt really important,,you watch it as it goes off when you start,if it comes on when under way something is about to crap,ive pulled a couple from 500/550 motors that were ex go cart and they have a reverse sense switch,,i assume this was rigged into the ignition so it wont start until oil pressure comes up?
Offline petercb750
« Reply #9 on: October 09, 2011, 01:41:47 AM »
I've just replaced mine on the 750 with one from DSS. They're not that hard to get to and not that hard to change. Mine was leaking from around the plastic internal bit - it was just spinning freely in the housing...........making a hell of a mess. It wasn't leaking out the thread.
Peter.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline Eydugstr
« Reply #10 on: October 09, 2011, 05:13:50 AM »
Here's some part #'s for the oil pressure switch.  They were used on a lot of cars, so they're available in aftermarket.  The main differences will be the shape of the top part of the switch.
OEM Honda - 37240-P13-013 (current part #), 35500-333-014 (old #)
Echlin(NAPA) - OP6075
Beck Arnley - 201-1679
Standard Motor Parts - PS200
Borg Warner - S4135
A long time ago I had one start to leak on me, the light came on but the motor felt okay and was very close to home.  Got into the garage and found a small weeping around the part of the switch where the plastic meets up with the base.  Replaced the switch with OEM honda ($30) problem solved.  If I remember correctly had to remove the cam chain tensioner to get a socket on it, though.  Hope this helps!
« Reply #11 on: October 14, 2011, 12:24:38 PM »
I just purchased the Napa part ( Echlin(NAPA) - OP6075- $17.20 +tax) and will report on the install and how well it plugged the leak.
« Last Edit: October 14, 2011, 12:26:40 PM by DukieFrankenkit »
« Reply #12 on: October 24, 2011, 08:18:02 AM »
Ok, finally put the Napa part on and it does not let the boot fit over it- so if you are looking for the boot to fit perfectly over the top the Echlin Napa part is not for you.
That staunched quite a bit of leaking oil but it looks like the chain oiler will need some servicing. Is there any way to plug the leak without doing something permanent like JB weld? Something that can be undone?
