Author Topic: Tools: JIS screwdrivers  (Read 9438 times)
Offline Scott S
« on: August 24, 2010, 03:09:15 PM »
 I've encountered quite a few knackered Phillips head screws recently. Only tonight did someone tell me about JIS screwdrivers. He said standard Phillips head screwdrivers are slightly different.
 Where might one find some JIS metric screwdrivers? Or is this like a "muffler bearing"?
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Markcb750
Re: Tools: JIS screwdrivers
« Reply #1 on: August 24, 2010, 03:14:21 PM »
I bought some Crescent screw drivers that have a square shank and fit the Honda screws well.  I do not think they are labeled JIS.
Offline Really?
« Reply #2 on: August 24, 2010, 03:14:55 PM »
I and others have picked up these.
http://www.mcmaster.com/#jis-(japanese-industrial-standard)-screwdrivers/=742v21
The small drivers will say JIS on them.
The large drivers say JIS on the site but on the drivers themselves say Phillips.
I called and they said they were the correct ones and they feel perty good in the grove.  They look slighlty different than the other Philips I have so they must be them.
Fabricator (http://forums.sohc4.net/index.php?action=profile;u=9953) has these as well.
The Wife's Bike - 750K5
The Kid's Bike - 750K3
Offline Scott S
« Reply #3 on: August 24, 2010, 03:17:32 PM »
'71 CB500 K0
'81 Yamaha XS650
Offline Really?
« Reply #4 on: August 24, 2010, 03:20:53 PM »
Those look nice.  Never found that page when I was looking.
Offline Duke McDukiedook
  • Space Force 6 Star General
« Reply #5 on: August 24, 2010, 03:42:46 PM »
I'm not sure about the 500 BUT ALL 750 SCREWS ARE ISO, NOT JIS.
Thnks,
mgmt.
Offline Really?
« Reply #6 on: August 24, 2010, 03:44:06 PM »
You sure?  I thought I saw the dot on the heads.
Offline Really?
Offline markb
  • When I finish my current project I might be a
« Reply #8 on: August 24, 2010, 04:21:45 PM »
All I know is that my JIS screwdrivers fit the screws on my 750's better than my phillips do.  Maybe I have crappy phillips screwdrivers.
Mark
1969 CB750 sandcast #97 restored - Sold Restoration thread link
1969 CB750 sandcaxt #576 - Sold
1969 CB750 sandcast #1553 - Sold
1969 CB750 sandcast #1990 - Sold
1969 CB750 sandcast #5383 restored - Sold Restoration thread link
1970 CB750 K0 restored - Sold
2010 H-D Tri Glide Ultra Classic (Huh?)
Offline domer
« Reply #9 on: August 24, 2010, 04:39:50 PM »
a #3 phillips works quite well, the one i use is actually a #3 bit in a driver...
Offline robmanero
« Reply #10 on: August 24, 2010, 05:08:07 PM »
I use Snap-on screwdrivers. Nothing else feels close. They fit all the screws on my jap bikes perfectly. Very well engineered. Never strip one out. Huge difference over the Craftsmans I used to have. Try one and you'll see. For the stubborn ones, I have a Snap-on impact driver. Little pricey but again a huge difference. I used to have a generic one, you'd smash and smash at that thing and it might get the screw out but the screw would be trash when you were done with it. Snap on impact, I barely have to hit it and the screw is out, in perfect condition without so much as a scratch. If you really care about keeping the hardware nice on your rice burner, go out and buy some Snap-Ons.
« Reply #11 on: August 24, 2010, 05:20:14 PM »
Early JIS standard was not the same as ISO, ISO and JIS now are very similar to one another.
David
« Reply #12 on: August 24, 2010, 05:38:32 PM »
In the late 60s, Honda made the change to ISO on 6mm and larger screws. They do not have the dot on them. However, even on the 750 5mm and smaller screws are JIS. I was in Honda parts when this was going on and we had to order new hardware for the new models. I was just a kid, but i remember all the hub bub.
Lots of misinformation about this and anxiety about not having the right tool. Standard Phillips drivers work fine on 6mm and larger screws. Regardless of model. They don't have the dot.
I may be wrong but I'mm 99% sure I'm right.
The dot tells the difference. If there is no dot on the screw in question it is ISO/Phillips. On the 5mm and smaller which have the dot I think a #2 Phillips works fine anyway.
« Last Edit: August 24, 2010, 05:41:35 PM by MCRider »
« Reply #13 on: August 24, 2010, 05:40:38 PM »
Thnks,
mgmt.
Agreed on the 6mm and larger. Not the 5mm and smaller. They have the tell tale dot.
« Reply #14 on: August 24, 2010, 10:27:49 PM »
I noticed if I pick the correct appearing screwdriver and then get the next bigger one it works better. I have a snap on bit that works like a dream in my little battery impact. Zips em right out no damage no fuss. I tried to buy more bits like it, they no longer have that number.
Offline Trav-i
  • Has finally become an
« Reply #15 on: August 25, 2010, 10:29:53 AM »
I can attest to the difference in screwdrivers.  Since Fabricator bought those JIS screwdrivers life is a lot easier.  They fit all those small screws perfectly, so no more stripped screw heads.
Just my .02
Travis
Forum member #9962
1992 GL1500 Interstate
« Reply #16 on: August 25, 2010, 04:59:24 PM »
Anyone know the JIS size screwdrivers needed for the '74-76 CB550?
Anyone know a source for a long bit driver in JIS #3?
The RJR CoolTool's Vessel driver bits and screwdrivers only go up to a #2 JIS.
Thanks!
David
« Reply #17 on: August 25, 2010, 07:14:01 PM »
Thanks!
David
Do the screws you are looking to remove have the raised dot (or sunken dot) on their heads? If  they are 6mm screws like on the engine cases I'll bet dollars to doughnuts they don't and so they are ISO screws. An ISO/Phillips #3 is the tool.
The only JIS used after 1969 or so were the (very few) 5mm and smaller like hold the instrument cables in. For them a #2 Phillips will work just fine.
« Last Edit: August 25, 2010, 07:16:12 PM by MCRider »
Offline Deltarider
« Reply #18 on: August 25, 2010, 11:51:30 PM »
Why not bring the genuine screwdrivers (that are/were in the Honda tool kit) to the hardware store and buy identical screwdrivers of a somewhat better quality?
CB500K2-ED Excel black
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #19 on: August 24, 2017, 02:52:26 PM »
Necromancing this thread with an update:
This un-named set "3-Piece JIS Ultra-Grip Screwdriver Set" at MacMaster Carr:
https://www.mcmaster.com/#53325A61
Is in fact a 3-piece Vessel set of crosshead screwdrivers, #s 1, 2 and 3. At $34 per set it has everything you need for JIS screws, and nothing you don't.
I have a motorcycle problem.
« Reply #20 on: August 24, 2017, 03:06:16 PM »
Hey Nils...have you tried the Vessel Megadora 980 Impacta?
It's good for screw that are tight but when an impact driver isnt necessary.
https://www.amazon.com/Vessel-Megadora-Impacta-P2x150-Screwdriver/dp/B003BGZ9CO
Offline NobleHops
« Reply #21 on: August 24, 2017, 03:19:02 PM »
Wellllllllll.......
Yes, I have two of them. I use them for prybars. I don't find them effective as impact drivers, but it sounds like you do? I sure tried them, on some old CT cases and the like, classic old Honda crosshead case screws, many whacks before any joy. Then dug out 'Ol Blue and WHAM, 1 or maybe 2 hits per screw, done. 'Ol Blue gets the call first nowadays :-)
For that reason I do not feel like the big Vessel set including their impact is such a good value. If you need JIS, I think the smart money is on this three-piece set and use your other good flat screwdrivers and impact drivers for those tasks.
« Reply #22 on: August 24, 2017, 03:59:56 PM »
No, not a replacement as an impact driver!
Offline shawn57nomad
« Reply #23 on: August 24, 2017, 04:40:41 PM »
Scott, you may want to check out Wera tools.  I've used these and had others borrow and abuse them in the Millwright Trade and they just keep ticking.  I've found that they have lots of great quality tools also wrenches and the usual.  Super good quality, I'd say even better than the man in the truck can offer!
This oughta have a travel tool roll setup nicely:
https://www.kctoolco.com/wera-056490-tool-check-plus-bit-ratchet-set-with-sockets-metric/
Sent from my E6810 using Tapatalk
