Author Topic: When did airbox change??  (Read 1422 times)
Offline techy5025
  • 1969 Diecast and Sandcast 750's
« on: February 25, 2006, 05:46:05 PM »
At what point/serial number did the airbox change from the colored
plastic one to the black one?  As a second question... when did the
tach red marker move from 8500 to 8000? A search here did not
yield any answers.
The bike in question is in the 750-1029000 range and I can't decide
if all the parts are correct.
I seem to have lost the url of the website that had a lot of these type
of details....but the experts here always do  ::)
Jim
1969 750 K0 (Reborn)
1969 Sandcast 750 K0 (Reborn)
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
Re: When did airbox change??
« Reply #1 on: February 25, 2006, 06:44:00 PM »
I believe the changes you are asking about occurred with the K1, for sure the airbox color. The K1 started with frame numbers 1044XXX, so yours should be pre-K1.
Offline techy5025
« Reply #2 on: February 25, 2006, 07:29:35 PM »
Thanks Bob,
I think this bike has some new...almost correct parts.  I agree with
you about the airbox...not sure on the tach.  hmmmmm
Maybe I will look at it again. ::)
Jim
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #3 on: February 26, 2006, 04:29:54 AM »
I took another look at some material I have, in Mark Haycock's book it verifies that the tach redline changed from 8,500 rpm to 8,000 rpm with the K1. At the same time, the construction of the instruments themselves changed from acrylic materials to metal cases with actual glass lenses. I have a CB750 (aka K0) that is mostly correct save for the airbox and a K2 tank.
Offline techy5025
« Reply #4 on: February 26, 2006, 12:15:47 PM »
Bob.
Thanks for the research. :)
This is the bike in question...
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&rd=1,1&item=4614885232&sspagename=STRK%3AMEWA%3AIT
The tank should have black badge color rather than white...I think it is a K1 tank.  Also it looks like the baffles are missing
from the pipes, wrong airbox.....and didn't all the K0's have a cut (not rolled) front edge to the front fender? ???
This is a local bike and, even with the faults, looks pretty good.  I haven't been able to coordinate with the seller to
inspect it, but he is a good salesman on the phone.  ::)
Jim
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #5 on: February 26, 2006, 02:17:08 PM »
I couldn't find anything specific about the rolled vs. cut fender. I know it changed from one to the other, but I don't know when (e.g. during the K0 run or between the K0 and K1). I downloaded the pic from the rear and enhanced it a bit. The baffles are there and they appear to be correct. I can say it is in better shape than mine. Do you know what the engine ser# is? Good luck with the bidding.
Offline techy5025
« Reply #6 on: February 26, 2006, 04:07:56 PM »
Bob,
I don't know what the engine serial number is yet.  Would also like to look at the guages
and a few other high ticket items.  ::)  It looks pretty good though.
Thanks for the help.
Jim
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #7 on: February 26, 2006, 04:16:39 PM »
Jim,
I agree. Let us know how it turns out.
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #8 on: February 26, 2006, 05:11:38 PM »
Jim,
Took another look at the pictures for the auction, the instruments appear correct in terms of their construction.
Offline techy5025
« Reply #9 on: February 26, 2006, 05:29:59 PM »
Bob,
I agree.  He has no face shots so I can't tell if they are the original plastic lenses
or the K1 glass....could tell by the tach red range.
Also can't tell if it has the short chain guard.  Need a touchy/feely here.  ;D
Jim
2003 CBR600F4I
Offline Bob Wessner
  • "Carbs Suck!"
« Reply #10 on: February 26, 2006, 06:32:55 PM »
I went through "play detective" on mine as well. I believe the gauges are correct because the lenses appear flush at the edges. I believe the later glass ones had a rim/lip to hold the lenses in place. I don't think it has the short chain guard though. The only shot is through the rear wheel and it looks like the back tip of the gaurd extends out to the rear too far.
Offline Ted Nomura
« Reply #11 on: February 27, 2006, 02:03:09 PM »
yield any answers.
Jim
Your bike is a 1970 CB750 model which should have the original non-ribbed colored airbox.
The true CB750KO serial numbers are: Frame# CB750 1044826-1044947 and Engine # CB750E 1044848-1045145. There were only 121 of them. They had CB750K1 carburators but it's not certain if they carried the original CB750 air boxes. Any CB750s before that number are either 1969 0r 1970 CB750s although American Honda misidentifies them as CB750K0s. Any CB750 after that serial number that starts with "1" is a CB750K1 model.
1969 Honda CB750, two 1970 CB750, two 1972 CB750K2, 1971 CB500, 1975 CB550, 1976 CB400F, 1968 CL450, 1973 CL450, 1974 CB450, 1970 1/2 SL350K1, 1971 SL350K1, 1972 SL350K2, 1972 CL350, 1972 CB350, 1983 CB1000C, 1976 Kawasaki KZ900A4, 1976 KH500A8, 1979 KZ400B, 1983 ZN1300, and so on and so on...
Offline techy5025
« Reply #12 on: February 28, 2006, 09:49:17 PM »
Well, the guages were correct...forgot to look at the
chainguard.  The bike is in very good shape.
Unfortunately, I didn't win the auction so booooooooo. :(
I still want another K0 and there will be others.
Jim
2003 CBR600F4I
Offline techy5025
« Reply #13 on: March 10, 2006, 02:53:04 AM »
Well....too bad....got outbid by the Orange County Chopper guy whose starting a museum. Not
quite sure why he wants a diecast...with his money I would think a "sandcast" would be better.
Oh well.
Jim
2003 CBR600F4I
Offline dusterdude
« Reply #14 on: March 10, 2006, 05:21:49 AM »
figured he would be dumb enough to pay 5 grand for that bike
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline Magpie
« Reply #15 on: March 12, 2006, 08:47:14 AM »
Dumb like fox I think.
