Author Topic: What should I do before I take it apart?  (Read 663 times)
Offline Tugboat
  • Puppet
    • PseudoMoto
« on: August 26, 2010, 08:03:13 AM »
Long story short: trashed the top-end of my ’76 750F a while back and purchased a ‘76K motor to swap out for $200. The “new” motor was sitting outside under a carport – otherwise uncovered – but turns over and seems to shift through all gears. The guy I bought it from had swapped it out on his 750 for a larger engine, and (of course) said that it ran fine when he took it off and was just upgrading, not replacing. He seemed genuine enough and told me “If this here ain’t what I claim it to be, just give me a call and I’ll make it right.” The fact that he lives only a couple of miles away does give me a little reassurance... He also had about ten 750’s in different states of (dis)repair and had evidently been fixing them up & riding them since the 70’s.
Anyway, see the pix below. It’s missing most of the outer parts: oil pan, alternator & cover, points/plate & cover, shifter, kick lever etc. Part of me says: “Just throw it on the frame, swap all the parts over & ride the sucker!” But the (more rational) part of me thinks I should at least take the top-end off and take a look at the pistons, cylinders etc since it was sitting outside for a while. So I’ve got my gasket set from CycleX and my screw set from Jim Spillane and am ready to tear into it.
Any advice here? I’ve got Hondaman’s CB750 book and this forum for specific instructions, but am wondering if there’s anything I should do prior to tear-down.
Offline Gordon
  • 750K1, 550K2
Re: What should I do before I take it apart?
« Reply #1 on: August 26, 2010, 08:38:44 AM »
If it was sitting outside with the intake and exhaust ports open who knows what's inside the cylinders.
bollingball
« Reply #2 on: August 26, 2010, 09:20:01 AM »
$50 bucks at the  most
Offline domer
« Reply #3 on: August 26, 2010, 09:25:13 AM »
is that years of caked up chain lube or a horrible patch job from a busted chain raping the case?(last pic) you've got it out, might as well tear it down... you could always clean up the top end and toss it on your other motor.
