Author Topic: New throttle cables question  (Read 563 times)
Offline MikeJW
« on: August 26, 2010, 02:31:43 PM »
I just bought two new throttle cables for my '72 750K. Should I try to lubricate them with something before installing them?
If so, what to use?  Thanks
MikeinMemphis
1972 CB750K2
Offline Johnie
Re: New throttle cables question
« Reply #1 on: August 26, 2010, 02:34:37 PM »
No need to lubricate new cables. Many times that will cause more problems as dirt will then stick to the lubricant and build up.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Markcb750
« Reply #2 on: August 26, 2010, 02:40:38 PM »
I do not lubricate my throttle cables (motion Pro) they have a plastic liner which should eliminate the need for additional lubrication.
Lubrication brings with it the ability to retain contaminates, which then work themselves into the cable.
Be careful to avoid creating any sharp bends as this will make the cables hard to pull.
Offline MikeJW
« Reply #3 on: August 26, 2010, 02:48:58 PM »
Thanks, y'all. I just got these from MotionPro also.
Mike
1972 CB750K2
