Author Topic: Fuse rating?  (Read 734 times)
Offline SOHC4ever
Fuse rating?
« on: August 27, 2010, 01:18:50 PM »
Bike is a '76 750F.
I blew my headlight fuse the other night, swapped in the spare and was on my way. The fuse box says that it's supposed to be a 7A fuse, but the burnt fuse that I removed is 10A.
Is the 3A difference significant? Should I replace it with the correct 7A, or with another 10A?
Re: Fuse rating?
« Reply #1 on: August 27, 2010, 01:37:51 PM »
Is your headlight stock?
It's a sub fuse.  Meaning they should blow before the main if there is a problem on the branch.
If the main fuse is 15 amps, all sub fuses should total less than what the main can carry.
A 7 and a 7 total 14 which is less than the main's 15.
A 7 and 10 total 17.  Which means a 15 could blow before the branch fuses do.
Assuming you are reading the fuse box labels correctly, right now you know there is a problem with the headlight branch and the bike still runs.  If the main blew, you wouldn't know where to look and you'd have a dead bike.
Offline SOHC4ever
Re: Fuse rating?
« Reply #2 on: August 31, 2010, 09:46:55 AM »
Thanks, TT. This is helpful as usual.
First off, I think that the HL is a more powerful aftermarket lamp but it's unknown.
If I'm reading you correctly, the aftermarket headlight could use more amps than the stock 7 and, consequently, a previous owner has upped the rating on the main, say to 20, in order to run a 10A HL fuse with a stock 7A TL fuse - 17 on the branch and 20 on the main.
If that's kosher, I'll check the main to see if it's in fact 20, and replace the HL with a 10?
If in fact I have a problem on the branch, do I just follow along the branch measuring amperage to see where I'm over-drawing?
Re: Fuse rating?
« Reply #3 on: August 31, 2010, 10:42:58 AM »
The headlight is often stamped with it's wattage rating.  Find that.
Use the formula I = W/12.8 to find the current it consumes.
Add about 2 amps (10-15%) for a margin.
I trust the Honda engineers to install the correct size fuse.  PO behavior is often random with no evidence of thought beyond recognition of having a part on hand.
It is also possible that the fuse clip resistance increased over 30 years and the clip heating is/was melting fuses in the holder.  A higher rated fuse melts at a higher temperature, and a higher wattage headlight makes them run hotter.
A fuse that melts from over current melts near the center of the glass window.  A fuse that is having clip heating issues melts near the end cap.
A frustrated PO may have simply installed larger fuses cause he found some, or that he didn't know that the fuse clips need periodic burnishing/polishing to remove oxidation, be it transparent or visible.
Re: Fuse rating?
« Reply #4 on: August 31, 2010, 11:03:34 AM »
yep, seen that a few times!
Offline RAWNOG
  • Pretty pretty pretty pretty... Pretty good.
Re: Fuse rating?
« Reply #5 on: September 13, 2011, 02:16:55 PM »
Hey I doubt this is going to be answered but Im replacing my sub fuses both with 7amp fuses, from what I've read here I can do that without messing anything up....?
1975 CB550k
