Author Topic: need help and some advice  (Read 1296 times)
Offline wicat
« on: August 27, 2010, 07:28:34 PM »
Hey guys pulling my motor and tranny to rebuild my problem is getthing the motor out.  Any ideas on whats the best way to remove the motor? Also whats the best way to get the gaskets free of the motor once it s been removed and the drive chain?
Offline fastbroshi
  • Puppet
Re: need help and some advice
« Reply #1 on: August 27, 2010, 08:18:27 PM »
If it's a 550 you can get it out of the frame fairly simply, plus it's lighter than the 750.  If it's a 750, you'll probably have an easier go at loosening the bolts that hold it to the frame, setting it on its side, and taking everything apart.
If your chain has a riveted master, you can cut it off.  If it's got a clip type master, just take off the clip.
What bike do you have?
Just call me Timmaaaaay!!!
« Reply #2 on: August 27, 2010, 08:25:26 PM »
If it's a 750 mate, you gotta pull it out from the right hand side. Try putting an old mattress on the floor, and after undoing all the engine mounting bolts, lay the bike over on it's points cover, and pull the bike away from the engine. Cheers, Terry. ;D
Shooter
« Reply #3 on: August 27, 2010, 08:26:14 PM »
When I removed the engine from my CB550F it was easier than expected (and the engine was heavier than I expected)
I found the trick was to get the bike up on the centre stand, loosen off all the bolts and have the engine supported.  I used a small pump jack with a couple of bits of wood on top.
I think the whole procedure is well outlined in the workshop manual ( well it is for the CB550)
The engine is removed out the side.
Offline wicat
« Reply #4 on: August 28, 2010, 06:55:57 AM »
I have a 73 750. I tryed to jack it up already it seemed to work a bit but not completly. im going to try the side thing today and see what happens. wish me luck lol
Offline wicat
« Reply #5 on: August 28, 2010, 04:20:27 PM »
so i found my problem is that i didnt remove the oil filter cover and all that.  The new problem is the bolt is stripped and the wrench wont work so i what can i do to remove the bolt?  Could i use vise grips? any help would be great
« Reply #6 on: August 28, 2010, 05:59:32 PM »
Vise grips might work mate, or try a hammer and a chisel, the bolt is buggared anyway, so try hitting the head of the bolt in an anti-clockwise direction, and that should undo it for you. You can buy new bolts with 17mm heads (instead of the puny 12mm OEM) from JC Whitney for 12 bucks. Cheers, Terry. ;D
