Author Topic: Rear Footpeg Bolt Sizes?  (Read 737 times)
Offline Stogie1020
« on: August 28, 2010, 12:57:46 PM »
1978 CB750K with Honda 4-1.
PO took off original rear footpegs and gave them to me, but without bolts.  Right side has hangar bracket for the 4-1 exhaust along with a mostly stripped bolt that is too large diameter to put on the footpeg.  I could take the peg to HD/Lowes and trial and error it, but wondering if anyone knows the specs?  Anyone know the original specs for the bolts to hold on the rear rider foot pegs?
Thanks.
« Last Edit: August 28, 2010, 03:40:54 PM by Stogie1020 »
1978 CB750K
Offline cookindaddy
  • I sure love this bike!
Re: Rear Footpeg Bolt Sizes?
« Reply #1 on: August 28, 2010, 05:35:57 PM »
I have the same bike but checked on-line at www.mrcycles.com. Apparently it is a 10mm bole 28mm long. These are probably available with coarse or fine threads, like inch bolts but as long as you get a hex nut in the same pitch, the assembly should work and the bolt will go thru the hole in the frame and the muffler support bracket.
You will find it useful to be able to look up parts for your bike. The Honda fiches (a kind of high res photograph of a printed parts page) give some details of the parts often like the sizes of bolts and o-rings. What you will see at www.mrcycles.com and other places are reproductions of the Honda fiches. Maybe www.mrcycles.com is not the best one to use, others may chime in with their favorites?
George with a black 78 CB750K (in Lion's Head, Ontario, Canada)
« Reply #2 on: August 28, 2010, 05:49:33 PM »
SKU: 95701-10028-00
BOLT, FLANGE (10X28) (Honda Code 4086708
Courtesy of Motogrid and me
Offline Stogie1020
« Reply #3 on: August 28, 2010, 06:23:23 PM »
Awesome.  Thanks guys!
1978 CB750K
Offline Stogie1020
« Reply #4 on: August 28, 2010, 09:37:34 PM »
Worked like a charm!
10mm x 30mm 1.5 thread.
Thanks!
1978 CB750K
