Author Topic: 750 k5 cable routing?  (Read 1569 times)
Offline siter81
  • vintage bike junkie!
  • TOO MANY BIKES? NEVER
« on: February 26, 2006, 06:59:11 PM »
Does the clutch cable and front brake cable go between the guage mounting bracket and the tripletree clamp?Does any other cables take this path also ,tach cable, spedo cable, throttle cables?Anyone have a picture of soure of info on this?
Thanks
61 BMW R27 70 BMW R75/5  75 RD350
71 SUZUKI T500
75 CB750K5  Weisco 836, WEB CAM.DYNA IGN,KERKER,K&N,TAYLOR,GALFER,AGM ETC.
 01 HONDA VC11000C3 AERO.
74&75 DUCATI 860 GT'S
jsaab2748
Re: 750 k5 cable routing?
« Reply #1 on: February 26, 2006, 08:00:47 PM »
Clutch cable goes in thru the "hole" made by the gauge bracket and passes downward along the right side frame tube, secured to the tube by straps. Install this cable first. Next, install both throttle cables, starting with the "pull cable" first. These also go thru the "bracket hole" and criss- cross OVER the previously installed clutch cable, wrap around the steering neck to the left side of the bike, go under the tank mount cusions, and extend rearward under the tank and in the center of the frame to the carb linkage. The brake hose also goes thru the same hole on its way down to the brake lite switch/junction mounted on the lower clamp. This is the basic routing, it'll start to make sense when you try it. Sorry I couldn't send a pic. Speedo and tach cables do not route with other cables. Each one routes straight down, along the indents in the back of the headlite housing, then thru a loop bolted to the lower triple clamp on the right side of bike. Tach cable then goes thru a chromed clip attached to the horn on its way to the valve cover and speedo cable goes down to fender thru a rubberized loop on the right side on its way to the speedo gear. Best I can without a pic, wish you good luck. :)
Offline siter81
« Reply #2 on: February 27, 2006, 01:55:55 PM »
Thank you Sir.That should do the trick for me
71 SUZUKI T500
