Author Topic: sprocket ratios  (Read 2261 times)
Offline petercb750
sprocket ratios
« on: February 27, 2006, 03:30:41 AM »
greetings from down under.
My head is starting to spin trying to work this out.  ??? When I bought my 750K2 it had 17/47 front/rear sprockets. I'm putting new ones on (and new chain) and am going for the standard 18/48. What can I expect this to do to the ride? Will upping each sprocket by one tooth have no noticeable effect, as opposed to just upping one or the other? Is there a formula or calculation that you can do to work out what difference changing sprocket sizes will make to acceleration/top speed. I'm running standard transmission and wheel sizes etc.
Thanks in advance........
Peter.
1972 750/4 K2 (his), 1976 400/4 (hers)
1982 CB1100RC (ours)
Offline cb650
Re: sprocket ratios
« Reply #1 on: February 27, 2006, 03:47:19 AM »
Bigger front will lower rpms at any given speed but the bigger rear will raise rpms but not as much.
Generally 3 rear teeth are equal to 1 front.
In your case it will lower rpm some.
             Terry
Offline cb(r)
Re: sprocket ratios
« Reply #2 on: February 27, 2006, 05:36:44 AM »
hopefully this is not in the realm of thread hijacking but this was the general question I was going to ask.  I was just told this weekend that for every 5 teeth you go up it was equal to one tooth down.  thought I would see if that was correct.  anyone?
Offline Jeff.Saunders
  • Obsessed by Old Motorcycles
Re: sprocket ratios
« Reply #3 on: February 27, 2006, 06:04:00 AM »
It's fairly easy to calculate the impact - divide the rear teeth by the front teeth to get the ratios
17/47 = 2.765:1 ratio
18/48 = 2.667:1 ratio
Then is you take a given speed and rpm - say your bike cruises at 4500 at 65mph - divide the rpm by the old ratio and multiple by the new.
In this case:
4500 divided by 2.765 and multiplied by 2.667 = 4340 rpm - a small, but noticeable change - you would loose a small amount of acceleration, but gain on cruising.
Offline ofreen
Re: sprocket ratios
« Reply #4 on: February 27, 2006, 06:09:26 AM »
Peter.
It is a ratio, just as your topic title says.  A 47/17 combination gives you a 2.764 to 1 ratio (rounded off).  A 48/18 is 2.666 to 1.  That is roughly about a 3.5 percent difference.  At any given speed and gear with the 48/18 combo will give you about 3.5 percent lower RPM than the 47/17 combo.
Greg
'75 CB750F
Re: sprocket ratios
« Reply #5 on: February 27, 2006, 07:07:50 PM »
18/48 will gear the bike up to 2.66, you will cruise at a given speed for less revs.
if you want it to be as near as it was, you need to go 18/50 2.77 to 1 instead of your old set up of 17/47 2.76 to 1.
Sam.
Offline petercb750
Re: sprocket ratios
« Reply #6 on: February 27, 2006, 11:04:11 PM »
Thanks guys for all your help and responses  ;D Good info and all makes sense.
Peter.
eldar
Re: sprocket ratios
« Reply #7 on: February 28, 2006, 07:40:26 AM »
You could also do a 17/46 or 17/48
Dont need to do the 18 unless you really want to.
