Author Topic: carbs not wanting to fill with fuel? 1978 cb750f  (Read 1221 times)
Offline motomotard
    • GoGo Garage
« on: September 02, 2010, 10:01:26 PM »
so ive just finished kinda putting my super sport back together.  top end has been redone, new gaskets, rings, etc.... other new doo dads.
i "rebuilt" the carbs.  took everything apart and cleaned em.  4 new carb kits installed, jets, gaskets, etc...
wiring harness and exhaust back on.. figured id try to start it.
when i hook the fuel line up to the carb it seems like the carbs are refusing to take gas...   they just wont fill.  bowls are still dry, i dont see any gas shooting out the jets.   it will turn over and if i spray some gas into the carb intake with the slides up and then kick it, it will run for a second then die out.
any idea what might be doing that?  tried two different tanks, dont think its a venting thing.. they just wont fill with fuel...
any help?
a pic of the beast in question from a little while ago
Offline Logan80
Re: carbs not wanting to fill with fuel? 1978 cb750f
« Reply #1 on: September 02, 2010, 10:56:35 PM »
Have you tried turning the petcock to On and Reserve with the fuel lines not attached to see that it flows fuel properly?
Offline motomotard
    • GoGo Garage
« Reply #2 on: September 02, 2010, 11:12:04 PM »
oh yea.  fuel is comin out of the tank fine.
its just not going into the carbs.   the line will fill up and just sit... its wierd
« Reply #3 on: September 03, 2010, 12:53:10 AM »
Did you put the floats in upside down?
At any rate, the float valves control carb filling if there is fuel in the feed pipe(s).
« Reply #4 on: September 03, 2010, 02:17:22 AM »
Damn! Lloyd beat me to it.  ;D
Offline motomotard
    • GoGo Garage
« Reply #5 on: September 03, 2010, 08:43:40 AM »
dont think so.. but i can check.   i wouldnt put it past me.
Offline motomotard
    • GoGo Garage
« Reply #6 on: September 03, 2010, 10:03:43 PM »
yup.. im an idiot.  two of the floats were in upside down.  dont know how i did that, musta been late at night and i wasnt payin attention.
fixed that and it literally started on the first kick.  wow.  my harley was never this easy.
<object width="480" height="385"><param name="movie" value=" name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src=" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
« Reply #7 on: September 03, 2010, 10:25:24 PM »
Ha ha, don't feel bad mate, you're only a motomo 'tard.............  ;D
