Author Topic: aluminum rods these any good?  (Read 14877 times)
Re: aluminum rods these any good?
« Reply #25 on: September 06, 2010, 07:55:33 PM »
notching not a problem. some vtwins notch a bite size chunk out of the sleeve when you get up in the large bore sizes, and long arms.... a buddy is running 4.25 pistons in his...
« Reply #26 on: September 06, 2010, 08:21:54 PM »
Oh, OK Frank, good to know. Your mate could use Triumph Rocket III pistons! ;D
Offline BLUE71TURBO
« Reply #27 on: September 06, 2010, 08:56:17 PM »
The rods in this thread were forged and made in Japan. They were imported by MC Supply in Los Angeles. They had more mass than the SuperRod / Yoshimura alloys.  We sold a lot of them back in the day for motors up to 890cc. Wouldn't waste money on them today, especially with bigger motors.
Im building an 836, planning on sending the crank to you to be lightened and balanced, firm believer in balancing everything possable here.
So do you know what the weight was as compared to a stock rod?
   I measured my MTC aluminum rods and one assembled rod weighs 260 grams ( 9.17 ounces )  not including bearings.  ;D
Here's another post us members had on the aluminum rod subject... http://forums.sohc4.net/index.php?topic=70578.0
« Last Edit: September 06, 2010, 09:02:08 PM by BLUE71TURBO »
Offline Big Jay
    • CBRzone
« Reply #28 on: September 06, 2010, 09:00:45 PM »
MTC Rods were very beefy. Probably weighs more than  the rods in this thread.
a700guy
« Reply #29 on: September 07, 2010, 10:22:24 AM »
Thanks BLUE71TURBO that gives me a "less than this number" at least, not
A bad weight savings.
FWIW there is a set of MTC rods for a sohc 750 on ebay right now too.
« Last Edit: September 07, 2010, 05:35:15 PM by a700guy »
Offline BLUE71TURBO
« Reply #30 on: September 07, 2010, 05:52:13 PM »
 I'll have to keep an eye on that auction, as i'm thinking of selling my MTC rods.   ;D
 I just looked for the MTC rods you were talking about and all i could find is the cheap japanese rods.   ???
« Last Edit: September 07, 2010, 05:57:26 PM by BLUE71TURBO »
« Reply #32 on: September 07, 2010, 07:36:41 PM »
Is it just me (probably) or do those look like Yoshimura Super Rods?
Offline BLUE71TURBO
« Reply #33 on: September 07, 2010, 08:06:44 PM »
a700guy
« Reply #34 on: September 07, 2010, 09:01:33 PM »
he misspelled aluminum
« Reply #35 on: September 07, 2010, 09:12:46 PM »
Depends where you are , Aluminium is what we call it in Australia and most of the rest of the world.
« Reply #37 on: September 07, 2010, 09:57:00 PM »
MTC Alumiumn Rods
Now thats some agricultural spelling....
Offline BLUE71TURBO
Re: aluminium rods these any good?
« Reply #38 on: September 07, 2010, 11:32:37 PM »
 Two way's to spell it ..........http://en.wikipedia.org/wiki/Aluminium    ::)  :D :D
« Last Edit: September 07, 2010, 11:59:23 PM by SamCB750A »
  • Moderator
« Reply #39 on: September 07, 2010, 11:57:18 PM »
Yes, the right way and your way. ;D ;D ;D ;D
Sam. ;)
« Reply #40 on: September 08, 2010, 04:21:34 AM »
Don't be too worried guys, just because Brit's invented the language, not all that many of them can actually speak, or spell, "English", either. ;D
a700guy
« Reply #41 on: September 08, 2010, 07:37:31 AM »
It's not spelled either way MTC Alumiumn Rods Honda CB750 K F A 69-78 CB 750 CR 750
  • Moderator
« Reply #42 on: September 08, 2010, 07:52:22 AM »
Perhaps the seller is dsyeltcic. ;D ;D ;D ;D
Sam. ;)
« Reply #43 on: September 08, 2010, 08:06:43 AM »
Yeah, and there really is a Dog..
 glaed Ihm nawt slysdexic................................ ;)
 A forum member Fishhead, has run a few sets of them MC Supply aluminum rods, and they seem to work on some motors.
a700guy
« Reply #44 on: September 08, 2010, 08:17:02 AM »
So I saw two main concerns for aluminum rods, corrosion and stretching.
If one isn't screaming an engine to 11000+ rpm stretching shoudn't be an issue, but I cannot figure out what the other concern for aluminium in street use is, does anyone know?
« Reply #45 on: September 08, 2010, 08:48:17 AM »
I ran a cammed motor to 10 or 11K pretty well everyday, with stock rods.
 Not sure what RPM you plan on.. the only way I can see it being lower is with a mild cam.
 One of the problems with (forged)aluminum rods, once they are used, they are iffy.. no way of telling how much life is left.. unless the hrs are documented.
 New ones, better scenario. As far as I know the Superrods (Yoshi) and MTC are not the same..
Offline fishhead
  • Why don't you go.....Well, you know the rest.....
« Reply #46 on: September 08, 2010, 11:50:28 AM »
 I've used the MC supply rods on a couple motors(836cc's, mild cams) and I have another set that I will end up putting on my bike when I install my 900cc kit.
 I haven't had any problem with the MC rods and I would (and I am going to) use them again.
Quote from:  Vanna White
Photobucket slide show (Fishhead Big Brakes)
http://s111.photobucket.com/albums/n130/dgfischer/Fishhead%20Big%20BRakes/?albumview=slideshow
Offline voxonda
« Reply #47 on: September 08, 2010, 12:38:11 PM »
Back in the 70's we raced with the Yoshi rods for 3 seasons and after the bike changed hands, at least another season of all out racing and no problem. Class limited to .5 m/m overbore = 748cc. With lightened crank, and Daytona cam it revved like a maniac and stayed in one piece. Really hope to find these Yoshi rods.
Rob
  • Moderator
« Reply #48 on: September 08, 2010, 12:52:45 PM »
If one isn't screaming an engine to 11000+ rpm stretching shoudn't be an issue, but I cannot figure out what the other concern for aluminium in STREET use is, does anyone know?
Let's put this thread to bed. what do you expect from your motor, is it a street or race motor?
You knew the answer to your origional question because you gave the answer in your first post.
Please tell us what you want to know.
Sam. ;)
« Last Edit: September 08, 2010, 12:55:50 PM by SamCB750A »
Offline Bill/BentON Racing
    • BentON Racing
« Reply #49 on: September 08, 2010, 05:41:44 PM »
Rob,I got a set sitting on midget motor crank.Maybe trade for mounts etc.The motor wasn't run long...looking at head,pistons etc.Rods I don't know.Bill
Should have wiped out wristpin hole! ;D......deposit on dry clutch? ;)
BentON Racing Website
BentON Racing Facebook
