Author Topic: My cafe project progress  (Read 40138 times)
Offline swellguy
  • An electric cattle prod is a
  • Divorce is so expensive because it's worth it.
    • http://ksphotos.com
« on: September 05, 2010, 10:34:56 PM »
I started this project with a stock 73 cb750:
Most of the design relies on Benji's body parts, including fork covers, headlight bracket, round tailsection and Trixie exhaust:
Side view:
Fork covers/headlight bracket:
I've upgraded to 29mm Keihin carbs, Dyna electronic ignition and some Dunlop K-70s. I'm using a Cycle X top tree with xs650 gauges in a relocated ignition cluster with clip on handlebars:
Now that the rear end is back on the bike, I'll be installing the Trixie 4 into 4 exhaust:
Simple flush mount taillight in the rear seat cowl (3/4 view):
Micro LEDs for signals, flush mounted to headlight bucket and rear frame:
Paint will be dark gray candy over small silver flake with darker/black shading into knee cutouts and the bottom of the seat and tank which will have these emblems:
Still working on a cable activated remote master cylinder for front brake. Still debating between stock switches or simpler custom aftermarket ones.
I'll post further photos as things progress.
This project started in confusion and will end in disarray.
http://forums.sohc4.net/index.php?topic=76471.msg852227#msg852227
Offline Speed King
Re: My cafe project progress
« Reply #1 on: September 06, 2010, 07:06:16 AM »
Really nice job. Can't wait to see more.
Offline joe29
« Reply #2 on: September 06, 2010, 08:49:22 AM »
Looking good so far!  Which BCR tank is that?
-joe
1976 CB750K
1974 CB750K
1972 CB750K
« Reply #3 on: September 06, 2010, 08:53:17 AM »
Looks really good. :o
 What are you doing with the stock tank & covers? may need  a set of them in a few months......754..
Offline swellguy
« Reply #4 on: September 06, 2010, 09:45:57 AM »
Dolphin tank and seat with the cowling extended in the rear and inch or two.
Offline Ricky_Racer
« Reply #5 on: September 06, 2010, 10:17:26 AM »
XS650 gauges? Really? Incredible! Okay, what did you do to make them work? Thanks! RR
Offline swellguy
« Reply #6 on: September 06, 2010, 11:06:35 AM »
Well they aren't working yet because I still haven't reassembled the wiring loom and hooked up cables, but I'm always curious when someone italicizes their words on bike forums. Is there something specific you had in mind?
Offline domer
« Reply #7 on: September 06, 2010, 12:03:28 PM »
sweet bike... the speedo from the xs650 shares the same ratio, but it appears the tach does not. 750 is 4:1, quick google turned up the xs as 5:1...
Offline swellguy
« Reply #8 on: September 06, 2010, 02:52:17 PM »
90 degree angle drives to allow for fitment of both gauges:
One unit is 1:1, the other made to accomodate 4:1 to 5:1 gearing.
Offline domer
« Reply #9 on: September 07, 2010, 06:32:03 AM »
I'm intrigued, where did you find the angle adapters?
Offline Mayor08
« Reply #10 on: September 07, 2010, 11:17:07 AM »
WOW if you put RGB2410 into a search engine you'll get links to websites where they can be purchased.  Amazing....
Scottish ex-wife Brit Mistress
Offline haggeo
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
« Reply #12 on: September 08, 2010, 06:35:19 AM »
Are you going to sell any of the stock parts you removed like the pipes and the covers? I'd like to have them if you are.
« Reply #13 on: September 08, 2010, 08:58:08 AM »
see Reply #3, have not yet got an answer..
Offline mycb750k6
  • Rocketman
« Reply #14 on: September 08, 2010, 09:07:57 AM »
Fair enough. How about the exhaust.
Offline Ricky_Racer
« Reply #15 on: September 08, 2010, 09:28:39 AM »
Like most here, I'm always looking for parts interchanges that actually work. I was intrigued as to how you were going to reconcile the ratios, but it looks like this thread has turned up a really interesting solution. The XS650 gauges look much better than the "pie pan" CB750 clocks.  RR
Offline swellguy
« Reply #16 on: September 08, 2010, 10:08:51 AM »
Sorry about the lack of response. I'm planning on holding onto most of the things I took off because right now until I have the bike complete and running, I can't think about what I have left to sell. I'll use this thread as a guide as to who asked for what first if that's ok.
« Last Edit: September 08, 2010, 05:46:29 PM by swellguy »
« Reply #17 on: September 08, 2010, 07:34:14 PM »
Sounds good to me..& Thanks..
 Let me know if you need any small bits made, I am fairly close to you..
Offline jhivy
« Reply #18 on: September 09, 2010, 09:42:16 AM »
What kind of levers and bar controls are you using?
Offline swellguy
« Reply #19 on: September 09, 2010, 06:12:59 PM »
Levers- standard cable levers for brake and clutch. Front brake setup includes a remotely located master cylinder.
Controls: ebay motocross controls, left controls lights (hi-lo), turn signals, horn, kill switch. Right is starter switch.
Offline swellguy
« Reply #20 on: September 09, 2010, 09:18:26 PM »
Quick photo, sorry for the quality:
Fitting the Trixie exhaust, not as simple as it looks.
Offline brandEn
« Reply #21 on: September 09, 2010, 09:32:39 PM »
Bike looks great. I love that seat and tank combo from Benji's but man they are spendy. I would love to have set like that in the alloy flavor.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #22 on: September 09, 2010, 09:40:44 PM »
I love the pipes but jesus thats pricy
1975 CB750K
Project Back in Black
Offline swellguy
« Reply #23 on: September 09, 2010, 10:01:48 PM »
I know but the alloy was just way too much. Couldn't have afforded the exhaust otherwise.
Offline joe29
« Reply #24 on: September 10, 2010, 08:36:46 AM »
Could you give more details on what you mean by by "extended"?  Also, any concerns about the rear tire bottoming out on the frame?
-joe
1976 CB750K
1974 CB750K
1972 CB750K
