Author Topic: RC 67mm Venolia Pistons  (Read 4223 times)
Offline mick7504
« on: September 06, 2010, 05:59:27 AM »
Can anyone throw some light on the rubberised inserts and the reason for them?
The pistons have a built in taper of .035" and the inserts measure just a whisker over the skirt base diameter.
If I was you
I'd be worried about me.
  • Moderator
Re: RC 67mm Venolia Pistons
« Reply #1 on: September 06, 2010, 06:14:47 AM »
They are teflon buttons mick, can't come out like a circlip.
Sam. ;)
« Reply #2 on: September 06, 2010, 07:18:14 AM »
Some early thinking I suppose, but I can't help.
I'm curious if there is any means to attempt oiling the pin in the boss? No holes in the underside.
Offline Steel Dragon Performance
    • Steel Dragon Performance
« Reply #3 on: September 06, 2010, 07:28:38 AM »
They were used to reduce piston skirt drag on racing pistons. Life was not long on them, engine would be rebuilt after so many races.
  • Moderator
« Reply #4 on: September 06, 2010, 07:32:26 AM »
Well spotted Brent, I didn't even notice that the buttons were in the skirt and not in the pin hole.
They are still probably teflon buttons though, to reduce heat in the skirt.
Sam. ::)
« Reply #5 on: September 06, 2010, 07:46:43 AM »
yes they were teflon buttons. I have seen them in dirt bike pistons to.
« Reply #6 on: September 06, 2010, 07:58:23 AM »
 That's a lot of piston for a 15mm pin Mick. ;)  They have been balanced as a set and, of course, have the vertical gas ports.
Offline Big Jay
    • CBRzone
« Reply #7 on: September 06, 2010, 10:28:03 AM »
Unless you have a pin that will handle that and more; http://aperaceparts.com/wristpins.html
In top fuel motors, the skirts were undersize and the buttons installed, then turned in a lathe. This way the piston could never contact the sleeve.
« Reply #8 on: September 06, 2010, 01:49:00 PM »
When did you start making 15mm pins Jay.......I haven't seen them in your catalogs for years and years.
Offline kos
    • m3racing.com
« Reply #9 on: September 06, 2010, 04:13:32 PM »
Sam. ;)
Sam, Look again, those are in the thrust surfaces of the piston, like drag racers do. Not anything to do with wrist pins.
KOS
220...221, whatever it takes.
Offline kos
    • m3racing.com
« Reply #10 on: September 06, 2010, 04:15:21 PM »
Thanks Mike for pointing this out and for Jay for making them!  Great news for us engine builders...
KOS
M3Racing USA
Offline mick7504
« Reply #11 on: September 06, 2010, 09:44:13 PM »
Thanks to everyone for your input.
Very much appreciated.
If I was you
  • Moderator
« Reply #12 on: September 06, 2010, 11:33:35 PM »
Sam. ;)
KOS
Reply #4 Mark, please wake up. :D :D :D :D :D
Sam. ;)
Offline NitroHunter
  • Radical Street / Strip Turbo
  • A man's motorcycle is a reflection of the man
« Reply #13 on: September 07, 2010, 03:21:08 PM »
Before modern coatings came on the scene, those Teflon skirt buttons were a common piston crutch in nitro motors. Due to skirt galling, it was not unheard of for cars to go through 4 BOXES - yes 32 pistons - in a race weekend ... and I've seen occasions where THAT was not enough!  :o :o :o :o :o
And guys tried like crazy to keep from having to pull the heads...  ::)
 Torco Nitro 70 motor oil was a godsent.
« Last Edit: September 07, 2010, 03:24:26 PM by NitroHunter »
Robbie the NitroHunter                      Fuel Coupe Hired Gun                  NHRA T/F 640
DRAGBIKE USA XH/MB Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=127179.0;attach=332735
DRAGBIKE USA XH/SS Recordholder: http://forums.sohc4.net/index.php?action=dlattach;topic=63940.0;attach=103300
Young mans glory days in the lanes: http://forums.sohc4.net/index.php?action=dlattach;topic=45685.0;attach=66341
