Author Topic: dyna coil wires  (Read 1182 times)
Offline johnyvilla
dyna coil wires
« on: September 06, 2010, 02:31:48 PM »
Does anyone have a better way of securing plug wires to Dyna coils other than soldering, at the connector? When I soldered mine this spring, I remember there being to much smooth material in the connector supplied with the coils, to really hold solder properly. I stuffed the thing hoping the mass would touch all sides and not disrupt the current.  Now one of my plug is firing intermittently and I'm rethinking solder.
Offline 68grandprix
Re: dyna coil wires
« Reply #1 on: September 06, 2010, 07:17:02 PM »
What kind of Dyna coils? I've got the 3 ohmers that use a standard male plug wire. Maybe a pic will allow someone to form an idea of a better way? Jim
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
Re: dyna coil wires
« Reply #2 on: September 06, 2010, 10:34:00 PM »
ditto
1975 CB750K
Project Back in Black
Offline johnyvilla
Re: dyna coil wires
« Reply #3 on: September 07, 2010, 02:42:09 PM »
I have the three ohm dyna coils. The connectors that came with either the z1 wires or coils, (I don't remember) are basically a metal tube, with a place to crimp the insulator. The rest of the tube is of larger diameter then the ignition wire. I could take a picture in a few days.
