Author Topic: 750 engine clean up. Removing old paint.  (Read 1514 times)
Offline fmctm1sw
« on: September 06, 2010, 06:15:09 PM »
Before and after photo of painstaking paint removal.  I'm not shooting for a polished engine nor do I want to remove the engine from the frame right now.  About an hours worth of work I figure.  Done with aircraft stripper, razor blade, fingernails, and wire brush (so far).
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline 68grandprix
Re: 750 engine clean up. Removing old paint.
« Reply #1 on: September 06, 2010, 07:13:11 PM »
00 or 000 steel wool works pretty well for cleaning up chrome. It can really make it look new. Also, there is another thing I've found that helps with tedious, mind-numbing jobs like this. Beer
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #2 on: September 06, 2010, 07:51:25 PM »
I just cleaned my ATC70 engine by putting it into the sandblast booth and glass bead blasting it. (lightly) Came out great, looks like aluminum again and more importanly it looks even with no more wear spots. I ended up rattle can aluminum-ing it. Why? Just because I liked it better with the paint. ;D
Good luck with that cleanup.
Offline Old75_ratafe
  • CB750 Cave Spelunking
  • 1975 CB750K
« Reply #3 on: September 06, 2010, 10:37:50 PM »
For inbetween the fins I've been using those dark redish 3m scuff pads used to prep surfaces for painting.  Works good to get the corrosion out and you can find them at most autoparts stores like O'reilly.
« Last Edit: September 07, 2010, 08:50:29 PM by Old75_ratafe »
1975 CB750K
Project Back in Black
Offline fmctm1sw
« Reply #4 on: September 07, 2010, 03:03:01 PM »
Thanks for the advice.  One thing to add to my growing "dumb ideas" list:  Don't scrape off aircraft stripper with fingernails...   ::)
Quote from: 754
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
« Reply #5 on: September 07, 2010, 06:28:23 PM »
yeah, that stuff is basically a methalene chloride gel...your body will absorb the meth and it stores in your fat cells. bad stuff. I use 5f5 for paint stripping...they even have an eco-green enviro orange crapolla. works.
  • 1975 CB750K
« Reply #6 on: September 07, 2010, 08:51:23 PM »
Ouch....
1975 CB750K
