Author Topic: 74 CB350F where is the CCT bolt at on this bike  (Read 1730 times)
qcextreme
« on: April 27, 2005, 06:48:17 PM »
My cam chain is making alot of noise, I look in the faQ and found how to adjust it but not sure where the bolt is?
don_m
Re: 74 CB350F where is the CCT bolt at on this bike
« Reply #1 on: April 27, 2005, 07:37:27 PM »
At the front of the engine above the oil filter.  Undo the lock nut & loosen the bolt, then apply a little forward torque on the crankshaft to put the tension at the front & the slack at the rear.  Now tighten the bolt & locknut.  If the chain is still loose, you have a problem, so follow the thread on correction.
Psycle Don
Offline heffay
« Reply #2 on: April 27, 2005, 08:44:01 PM »
searched for "correction"... no go... need more keywords
