Author Topic: cb350 vs cb360  (Read 4103 times)
sanderson
cb350 vs cb360
« on: September 09, 2010, 10:44:57 PM »
Okay i have aquired two bikes in the past couple years, i was given a 72 CB350k4 twin  that is in fair shape but needs alot of cleaning up to be a sharp bike. I have noticed these bikes dont resale for much so i am afraid to invest any money into it.
          I just bought a 75 CB360 twin that was in parts when i bought it and wanted to transform it into a cafe racer. It still needs alot of parts to rebuild it but i only gave $180 for it and all the parts i have are in better shape than any part on the 350.
   Now i have noticed since i have become obsessed with looking into these bikes on the internet that the 350 seems to be the more popular bike or motor i should say. Is there a reason for this?sit because there were more of them produced or are the motors that much better, keep in mind the 350 i have has a 5 speed trrans and the 360 has a 6 speed. I wanted to do some sllight engine mods onm the 360 like cam chain and slider, mikunis, exhaust and head work, but am i doing this to the wrong bike? should i be investing in the 350 instead?
I have the engine apart now on th 350 to hone cylinders and replace rings and was gonna put stock tensioner wheel back in to use a a steady rider while working on the 360. The 360 needs wiring harness, seat, gas tank, drive chain, wiring harness lots of bolts and the upper triple tree is cracked on both sides. The 350 is just rough all around and needs, new wheels and spokes frame painted and alot of rust removal and elbow grease. Let me know what you guys think, if you like i could post pics
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
Re: cb350 vs cb360
« Reply #1 on: September 10, 2010, 04:30:37 AM »
The 350 was made more years 68-73. The 360 74-76 it had some problems with cams supposedly and a few hp less just like the 350F 4 cylinder did too. But the 360 had a 6 speed.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
Offline kirkn
Re: cb350 vs cb360
« Reply #2 on: September 10, 2010, 05:56:38 AM »
The 360 is the less robust of the two.  It was designed as an 'econo' bike motor unfortunately.  And, AFAIK, there never really was any kind of aftermarket 'hot-rod' stuff for the 360.
The primary weakness was the fact that the cams ran directly in the aluminum of the head, rather than in any bearing.  So, dirty oil or oil starvation could ruin the entire head.  That being said, MANY bikes, not just Hondas, did that and none had a real problem...    I mean, if you don't change or check the oil, ya get what ya get, IMO.
The early models had cam chain tensioner problems too.  There was a recall, and later models were OK from the factory.  If there is what looks to be a center-punch mark around the engine serial number, it has been repaired.
Another problem is that several pieces (cam tensioners included) are no longer available from Honda and not reproduced by anyone at all.  It can be VERY difficult to get new tensioners if your motor needs 'em.
The 360 is also prone to cracking the top triple clamp, as yours had.  Something about the way they needed to be tighted that was not intuitive, and most of the time the owner broke it.  It can be a challenge to find non-cracked parts, cause 'everyone' needs one...
Anyway, that's my two cents...
Good luck with 'em, and by all means, post up pictures!
Kirk
sanderson
Re: cb350 vs cb360
« Reply #3 on: September 10, 2010, 05:14:34 PM »
ARRRGH! I hat computer sometimes! Well it seems as if i will be either building or parting out the 360 then. I would like to swap front ends though since the 360 has the good looking forks and disc brake wheel assy. Will i have problems with my triple trees with the new shocks? I already have my 350 motor disassembled for repair so while i am at it i would like to improve on it, any suggestions for this? I dont know the prices on these upgrades but I would like to intall dual mikunis and have heard good things about the Tsubaki cam chain and slider type tensioner, I should probably install a new cam since swapping chains too. I found Todd Hennins website last night and started drooling on the keyboard! What is involved in installing the 67.5mm forged piton kit, besides boring the cylinders? What type of cam should i run for street application and will the Mikuni VM30 carbs work okay for that setup? All this may be way out of my budget, but budgets were designed to be broken....right? Here are some pics of my bikes
