Author Topic: Project "Mini Me" General 5 Star Moped  (Read 9844 times)
Offline oldhondarider
  • http://indimediaimages-shepdog.blogspot.com/
Re: Project "Mini Me" General 5 Star Moped
« Reply #25 on: September 29, 2010, 08:06:45 AM »
After I drained the tank I flushed it with water, then added 2 stroke oil and shook it around... but it still flash rusted...
Now the tank looks worse than it did... although this rust is a very thin layer.
I think what I'm going to do next is let it soak for a few more days, and have a full can of pre-mix fuel waiting...then drain the tank of vinegar and immediately fill the tank with fuel.
[/quote]
i tried the vinegar trick... I to believe it worked well... but no where as good as Evaporust... That stuff is the SH*****T!.  Completely changes the rust to inert..  quick flush and a spritz with WD40...   IMHO.
"I have never seen a wild thing feel sorry for itself. A little bird will fall dead, frozen from a bough, without ever having felt sorry for itself."   D. H. Lawrence
Welsh Customs, Tacoma Washington
Offline zanorak
  • Surviving the Apocylipse quite well.
« Reply #26 on: September 29, 2010, 04:39:36 PM »
Yeah, you're supposed to clean the water out with WD40 I think. Mine did the same thing and I just put in some inline filters. ;) Lazy solution. This winter I'll do it right.
Offline laser145
  • underfunded
« Reply #27 on: September 29, 2010, 09:38:30 PM »
I'm thinking about draining the vinegar and then just filling it with pre-mix, shake it around, filter it out and refill it again... skip the water flush altogether...
We'll see, it's all experimental at this point. I'm learning from this moped, skills I will carry over to my next SOHC.
