Author Topic: 350 Front brake issues .... dragging.  (Read 1365 times)
bonfire
« on: September 10, 2010, 04:42:29 PM »
Hi,
 So I',m getting lot of sweaking and brake dragging. my pads are good and this problem only happens after I've been riding about 20 min. I was told the 350 had some problems with there brakes but not told how to fix this.
 side note. the SOB brake about locked up on me in a gas station parking lot..... ten min later it was fine.
Offline HondanutRider
Re: 350 Front brake issues .... dragging.
« Reply #1 on: September 10, 2010, 06:33:28 PM »
There have been lots of posts about dragging front discs.  Do a search and I'm sure you'll find lots of info/advice.  The key is proper cleaning and assembly with the correct lubrication.  They are a pain if not set-up correctly, but if properly assembled and adjusted - they work good..not great like modern braking systems, but good and not dragging.
