Doesn't matter what SOHC 4, I am just looking for information.
Please post the manufacture of your aftermarket ignition and the type of failure if you have had one.
Back Story:
I installed a Dyna unit on my K6 last year, for this whole summer i chased an intermittent loss of power during my rides.I blamed everything except the ignition, I cleaned and reinstalled the carburetors, reset the floats, then rebuilt and installed a nice set of F carburetors I had. I replaced the coils one at a time, I changed spark plugs hotter, then colder.
Finally, I determined it was the solid state ignition, #2&3 switch. That it fails when the motor is hot, that it runs fine with point cover off.
These two paragraphs took me several weeks of tinkering, and as usual I learned a lot of things about my K6, much more then when it is running well.
My experience with the Dyna service department has been less then pleasing. First thing they will not sell just the switch, they assume everyone is incompetent to remove two screws and two wires.
I got the RA#shipped the unit with a description of the failure mode, then waited three weeks for the unit to be returned.
I carefully documented the failure mode of only when hot, and no failure with the points cover removed. I measured the temp of the points cover after 1/2 hour of running and told them I felt the unit fails above 125 deg F.
Dyna ran it 25 minutes at a large gap with no failure, shipped it back to me without repair. No indication of testing at elevated temperature.
Short of it is, I am trying to decide should I fight on, make them fix the unit, of just give up, run on the points, and use the Dyna for a paper weight.
Thanks to Nikkisix for his advice & help
