Author Topic: TAO --- The South Seattle Cafe Project  (Read 153715 times)
Offline hapakev
  • Your Standard
Re: The South Seattle CB750 F3 Project: Spokes are DONE with new pics!
« Reply #450 on: November 21, 2011, 09:25:50 PM »
Wow, those are #$%*in Jim! Where do I send the money? :D
Smoking Jack
1978 CB750F(ish)
Offline solo 2
« Reply #451 on: December 12, 2011, 05:09:12 PM »
Your bike has been my screensaver for awhile now, brilliant build. If mine turns out 1/2 as nice I will be pleased.
You know you've achieved perfection in design, not when you have nothing more to add, but when you have nothing left to take away.
Offline brandEn
« Reply #452 on: December 12, 2011, 06:02:50 PM »
Thanks! Hopefully you will like it better when round 2 is done here in a few weeks.
Offline immortal
    • 1976 CB750F "Pegasus bike"
« Reply #453 on: January 05, 2012, 10:20:02 AM »
Hi Branden,
I wanted to ask you about your air filters, looks like the K&N. Have you had any difficulty tuning with them?
I have my Pegasus bike finished with the Uni filters and it runs rich and stumbles on acceleration and it seams to come down to air flow.
Hondaman tells me I need to switch to the stock airbox perhaps with a K&N filter as these pods are allways the problem for running rich and 1st quarter throttle air flow.
How are these filters working for you?
Thanks!
Sometimes...the hard thing and the right thing are the same thing!
1976 CB750F "Pegasus Bike"
http://forums.sohc4.net/index.php?topic=80492.0
Offline brandEn
« Reply #454 on: January 05, 2012, 01:48:10 PM »
Actually I haven't ran them yet and they are Dynoman filters not K&N. Also remember I am running CR29 carbs not the stockers. After I get the bike back on the road (VERY soon) I will can answer a bit better. With the stacks and screens I was running before she ran great.
Offline billyfrank
« Reply #455 on: January 07, 2012, 10:04:20 AM »
Well done!
I am also building a 78f right now(at least getting ready to) and was curious as to the wheel tire combo.  It looks like you carried over the tires, what size are they and what rim widths did you go with on the spokes?  Everything looks great and if some of those rearsets were available I'm sure they would sell like hotcakes.
Thanks for the constant inspiration,
Billy
Offline brandEn
« Reply #456 on: January 14, 2012, 10:55:40 AM »
LOTS of changes since my last update. Finally got the rearsets completed. FunJimmy went above and deyond to design and fabricate rearsets for tweakin and I. THANKS!!!! I was going to have them hard anodized but it was going to cost way to much so I went ahead and had them powdercoated. I also coated my new NOS Dresda swingarm and got that all buttoned up as well as my spoke conversion. I said what the hell and threw some new IKON shocks in the rear since I had new suspension with the GL1000 front end. While everything was apart I painted my CR29 carb bowls and slide covers and added K&N filters replacing the stacks I had. I was never happy with the Chromex on the pipes so it was recoated in Black Velvet satin ceramic. Frankenstuff sent me one of his new ribbed points covers to see if I liked it. I think it looks pretty cool just needs some paint. Now if I could just get some dry weather I could take her out for a shakedown run.
On the way... Black Anodized fork Superbrace, 530 chain conversion with black anodized rear sprocket from Sprocket Specialist and chain from Diamond Chain Co.
Offline VTEC
Re: The South Seattle CB750 F3 Project: PIC update 1/14/12
« Reply #457 on: January 14, 2012, 12:06:30 PM »
Hey man you did great job! Can't wait till I see it in person. Hopefully I'll get mine done some what Before it stops raining
Offline brandEn
« Reply #458 on: January 14, 2012, 12:36:49 PM »
Thanks VTEC, man we are practically neighbors. Where you been lurking? Got any info on your bike?
Offline VTEC
« Reply #459 on: January 14, 2012, 12:49:40 PM »
Offline cheapride
  • Work Hard Play Hard
« Reply #460 on: January 17, 2012, 07:08:59 AM »
Nice job with the rear sets.  What ratio did you go to on the 530 chain.  I used a 17 front and a 48 rear to tone down the interstate rpm's a bit.
1978 cb750f Supersport
Offline brandEn
« Reply #461 on: January 17, 2012, 09:22:00 AM »
I went with 17/48 as well.
Offline Freaky1
« Reply #462 on: January 17, 2012, 09:28:46 AM »
Isn't that a stock ratio? I did the 530 conversion also and I went with the same that my old 630 had. I could be wrong as I'm at work and can't just run out and look.
That which does not kill you leaves cool scabs which turn into awesome scars.
'77 CB750F Come on...were almost there!
Offline lucky
Re: The South Seattle 1978 CB750F Cafe project
« Reply #463 on: February 22, 2012, 07:16:00 AM »
The slide and needle assy
To get the needle out for adjustments you need to remove these two screws
My needles are not notched so to raise them I need to add a shim, just a small washer
One washer equals one notch on a notched set of needles
The flat section of the bottom of the slide will have .007" machined off
The stock slide is about 1.950" in length
Cleaned up float chamber
This is a pic of one of the jets on the #2 carb accelerator pump that needs to be cleaned
A can of carb cleaner with a straw makes a good way to verify it works correctly
This second jet was clogged and would not let any carb cleaner spray through it. A good overnight soak and lots of sprays with the carb cleaner and straw got it working like a champ. It sprays a nice even pattern now.
SHORTENED
Those square brass things you point to are NOT jets.
That square brass plug holds a check ball and spring.
The first one you show is to keep fuel from draining back down into
the accelerator pump chamber.
The bottom photo with the square brass plug is the check ball that can cause the accelerator pump to not work at all if it has corrosion.
I hope that shim you put on the needle was at least .040  thousandths thick.
You did not say how thick it was. Also the washer has to fit into that little recess inside the bottom of the slide or it will be cocked on an angle. Did the washer fit into that recess?
« Last Edit: February 22, 2012, 07:23:32 AM by lucky »
Offline brandEn
« Reply #464 on: February 22, 2012, 08:18:24 AM »
Thanks for the help lucky. That post is well over a year old. Better late than never.
Offline brandEn
« Reply #465 on: February 25, 2012, 10:37:54 AM »
Few new pictures with my completed FunJimmy/Joker rearsets. GL1000 front end rides nice and stable. Feels way different than the stock front end. The bike is about 95% completed (for now). I am still waiting on my Superbrace fork brace. I also need to tune the carbs on the dyno and adjust the fork oil. The 7W oil is a bit light. I am debating Racetech emulators and springs.
Offline brandEn
Re: The South Seattle CB750 F3 Project: SPOKES + REARSETS = DONE
« Reply #466 on: April 28, 2012, 04:33:48 PM »
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
Re: The South Seattle CB750 F3 Project: DYNO videos!
« Reply #467 on: April 29, 2012, 07:23:04 AM »
So. frigging. sweet. Great job man.
« Reply #468 on: April 29, 2012, 07:42:39 AM »
Great job BrandEn your bike looks and sounds amazing. Very inspiring!
Enjoy the ride (get some photos on "let's see your SOHC bike on the road" thread
Cheers
Andy
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #469 on: April 30, 2012, 08:29:05 AM »
71HP is impressive.....Guess you need to shift at 8K...any idea what that dip is at 4.5K?
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline brandEn
« Reply #470 on: April 30, 2012, 08:39:50 AM »
Yea the dip at 4.5 is the slide cutout being to rich. Soon to have leaner slides to try and tune it out.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #471 on: April 30, 2012, 07:53:03 PM »
You're gonna pull the trigger on the slides are you?
Offline brandEn
« Reply #472 on: April 30, 2012, 08:00:50 PM »
David is gonna swap me for the 3 mm slides out of his CR31's. At least let me try them out for now.
Offline tweakin
  • tear down
« Reply #473 on: May 01, 2012, 03:24:42 AM »
Thats great news B.  Nothing like being able to try them out before you have to drop the $$ on new ones.
I think I will hit the Twinline dyno in a couple saturdays from now.  I have to go to Portland this weekend but should be able to head up the the next.
Offline Doctor_D
« Reply #474 on: May 01, 2012, 07:18:22 AM »
Happy to be able to help out.  Branden, I'll try to return your call today.
And, to your question, Jameson's is always a safe choice.  ;D
Take care,
David
1978 CX500
1971 Norton Commando
