Author Topic: TAO --- The South Seattle Cafe Project  (Read 153937 times)
Offline brandEn
Re: The South Seattle 1978 CB750F Cafe project
« Reply #75 on: October 30, 2010, 12:49:49 PM »
Yea I am enjoying doing this thread. I just need money and parts to get this project really going!
Offline brandEn
« Reply #76 on: October 30, 2010, 01:14:42 PM »
I forgot to mention I dropped my valve cover, tappet covers, and breather cover off at Performance Coatings for some Chromex treatment.
« Last Edit: October 30, 2010, 01:16:18 PM by BWJ »
Offline tweakin
  • tear down
« Reply #77 on: October 30, 2010, 02:35:44 PM »
Nice, they do good work.  I have used them in the past.
Offline HedNut
  • Underwater Basket Weaving
« Reply #78 on: November 02, 2010, 05:44:25 AM »
Hey Steve-O....  as for welding with the electronics still on the bike... I don't see an issue... make sure the battery is out...as you said.... and remove the coils and wire harness from that area of the frame.   ALSO...I'd make sure everything is well covered up and protected from rogue sparks.
That's what I would do anyways...but somebody else may have better advice.  ;)
BWJ!  Keep up the excellent work!
Nice detailed post on the frame kit. I am on the list to purchase a kit for my new K7 project bike.
Looks to me like there are 8 spots that need to be welded?
Hednut - do you see an issue with welding this with all electrics still on bike? [I will have the battery out]
Thanks.
Offline brandEn
« Reply #79 on: November 02, 2010, 06:05:05 AM »
Thanks, I will try! If all goes as planned I will be welding my kit in this Friday. Looking forward to getting this portion of my project completed and checked off the list. I have decided I should probably get a cowl picked out and bought before I take the frame in for powdercoating in case I need to drill or modify anything for the install. I am having trouble picking one out. Any suggestions anyone?
Offline brandEn
« Reply #80 on: November 04, 2010, 06:07:22 PM »
Here are a few pictures of my carbs I just took. I am removing the slides to have .007" removed from the bottom. Cycle X is going to mod them for me on the lathe. I am determined to make these carbs work, and work good with my pods, 836 kit and new valve train. The boys at Cycle X have recommended to have the material removed for better throttle response at the low to mid ranges. I figured I would go ahead and give it a shot based solely on this recommendation. I did a forum search and could not find info on members that have done this so just gonna wing it with the help of Cycle X.
To remove the slide remove this screw
Then slide the spring and holder of the shaft
Ready to remove the slide
The slide and needle assy
To get the needle out for adjustments you need to remove these two screws
My needles are not notched so to raise them I need to add a shim, just a small washer
One washer equals one notch on a notched set of needles
The flat section of the bottom of the slide will have .007" machined off
The stock slide is about 1.950" in length
Cleaned up float chamber
This is a pic of one of the jets on the #2 carb accelerator pump that needs to be cleaned
A can of carb cleaner with a straw makes a good way to verify it works correctly
This second jet was clogged and would not let any carb cleaner spray through it. A good overnight soak and lots of sprays with the carb cleaner and straw got it working like a champ. It sprays a nice even pattern now.
This is the original accelerator pump diaphragm. The mouse ears are supposed have both holes open. The left one was opened up by me with a drill bit because it was closed up. Hard to imagine this bike ran around for 30 years with it like that!
Nice and clean!
« Last Edit: November 05, 2010, 01:39:28 AM by BWJ »
Offline tweakin
  • tear down
« Reply #81 on: November 04, 2010, 06:18:57 PM »
Nice!  so you made up your mind to go with the 836 kit, well done.  Any news from our friend the powdercoater?
Offline brandEn
« Reply #82 on: November 04, 2010, 06:38:29 PM »
Thanks Tige, Yea the 836 has become priority. I just would never be able to set my mind at ease if I didn't! I just talked to Jeff, my engine cases are done and now he is working on the rest of my other parts with the gloss black. I told him no hurry I will pick them up next week. I could tell he was relieved because he was planning on working extra late to get it all done.
Offline brandEn
« Reply #83 on: November 05, 2010, 02:17:36 AM »
I am digging this color combo for my bike. Black stripe down the center of the tank and seat cowl and metallic orange pearl as the main coat. What do you guys think? I really need help with this, I am not good at picking out colors unless its black!
« Last Edit: November 05, 2010, 02:27:58 AM by BWJ »
Offline HedNut
« Reply #84 on: November 05, 2010, 03:55:50 AM »
Wow... that would be a slick color combo indeed!!  Love it!  And it sounds like you're rockin' this bike hard!! Very cool!
Excellent pics!  Looking forward to the next step!
PS... I love your avatar!!  ;)  Looks SLICK!
Offline tweakin
  • tear down
« Reply #85 on: November 05, 2010, 06:08:42 AM »
YES!!  love the color combo.  Just trust your gut and you will be all good and build the bike you want.
Offline brandEn
« Reply #86 on: November 05, 2010, 04:57:32 PM »
Yea I am diggin that color combo too. Thanks for the reassurance. I will most likely end up with something similiar.
Picked up my valve cover from Performance Coating today. Best $50 I have spent on the bike yet! It looks awesome.
I also got my frame kit welded in. Not the most beautiful welds but it will work and the price was right.
I also did some cleanup/polishing on my head
« Reply #87 on: November 06, 2010, 09:02:23 AM »
I third the "like the color combo" - go for it!
Also like the valve cover job, $50 sounds pretty reasonable.
I'm going to look into polishing mine.
Offline brandEn
« Reply #88 on: November 06, 2010, 02:17:41 PM »
Thanks Stev-O, glad to hear the good input on my color choice!
I got my guage faces printed the other day. I am glad that I ordered two sets because I used them both. The printer made the decals so they needed to be applied to white backgrounds. The numbers and Honda logo could not be seen when I applied them to my green faces. So I painted one of them white for a test run. I was worried they may not illuminate well at night but was pleased with the way it all turned out. I got my tach almost completed I just need to figure out a way to seal them shut. The old gasket doesn't seem like it can be used again. I also need to get a couple hose clamps to hold the band that was cut to hold everything together while I let the epoxy cure. Has anyone run into problems with their guages from not replacing this seal?
Thanks HedNut!!!
« Last Edit: November 08, 2010, 05:07:59 AM by BWJ »
Offline CB550CAFE
« Reply #89 on: November 06, 2010, 10:35:32 PM »
You're doing an extremely thorough job, keep it up! Lovin' the Tach!
-Derek - 1976 CB550
« Reply #90 on: November 07, 2010, 02:36:52 PM »
+1! Gauges look great!
Offline brandEn
« Reply #91 on: November 08, 2010, 03:07:12 AM »
Thanks guys for the positive input!
Offline tweakin
  • tear down
« Reply #92 on: November 08, 2010, 05:28:43 AM »
The gauges look great, cool design.  Do they still illuminate well with the painted white base?  DO you plan on working on the bottom end this weekend?
Offline brandEn
« Reply #93 on: November 08, 2010, 05:36:22 AM »
Thanks, I worked with HedNut on the design. He is a computer guru! As far as working on the bottom end, I think I may get everything set up and inventory all parts and make sure I have everything needed. I would love to have ya help out when it comes time to slap the cases together. You still up for it? Did you happen to see my cases at Jeff's shop?
Offline brandEn
« Reply #94 on: November 08, 2010, 05:38:18 AM »
Oh yea, the guages light up great and can be seen no problem. I was worried about them not illuminating well but its not an issue.
Offline tweakin
  • tear down
Re: The South Seattle CB750F Cafe project
« Reply #95 on: November 08, 2010, 05:47:01 AM »
I will help with the bottom end, just give me a heads up.  I actually used my local coater this time since Jeff's stuff got jacked.  I didn't want to wait any longer than I had to.
Offline HedNut
« Reply #96 on: November 08, 2010, 07:14:16 AM »
Wicked!!  Gauges look good man! And the frame kit!  Props on all the good work going on!  JUST SLICK~!
Offline jdubb1977
« Reply #97 on: November 08, 2010, 01:10:08 PM »
2nd on the color choice!  black is way overdone, so be bold.  :)  if you can find the paint name/code, duplicolor probably makes a match to that orange.
Offline y2kc0wb0y
  • B00msh0cka
  • Shoot the pickle....
« Reply #98 on: November 08, 2010, 02:55:06 PM »
Subscribed. Enjoying your attention to detail and pace. Are back cuts on the valves and angles on the head helpful with the 836? Any pocket work? I'm new to the motorcycle world so I'm not sure if these things matter much to help velocity and VE. Suppose I could search as this is sort of off-topic.
I like the color combo but would do a matte black instead of gloss FWIW. :O)
CB750K3 890cc| 2004 VFR800A| 76 CB550F| 77 CB750F| 73 CB350G| 79 XLH| 2007 BMW R1200GS| CB750K2
Offline brandEn
« Reply #99 on: November 09, 2010, 01:34:36 AM »
Thanks guys! I found that the name of the paint on the Viper is called Toxic Orange Pearl aka Mango Tango Pearl. They both have the same paint code. I will give the matte black stripe some thought. I have seen that before and it may look pretty wicked.
Cowboy, I really am not the one to answer your technical questions but there are a ton of people on the forum that can answer that way better than I ever could. I am just going with a some mild polishing and your standard valve seat on my head. I would like to eventually send it out for a stage 3 port job. MReick on the forum is the head porting guru.
