Author Topic: Question about a simple wiring diagram from honda chopper.com  (Read 3425 times)
Offline sky56
  • would you like to see my
  • Chgo winters can suck but great time to wrench
« on: September 12, 2010, 05:58:41 PM »
im looking to run a simple setup on my chopper project and will be running no turn signals just a head and tail light. It appears that according to this diagram this is all il need. Any help will be greatly appreciated. heres a link to the website as i cant load the pic for some reason
http://www.hondachopper.com/garage/reg_rect_diagram/reg_rect_diagram.html
Many honda bikes and a lifted 75 Chevy K5
Offline sky56
Re: Question about a simple wiring diagram from honda chopper.com
« Reply #1 on: September 15, 2010, 04:40:40 PM »
Ok so i figured i would update this post so that anyone who chimes in is on the same page as me. my ignition (older honda one) cylinder has 3 positions off and then 2 dots next to the off spot. It has 4 wires coming out of it
1 solid black
1 solid brown
1 brown with white stripe
1 solid red
My motor has the typical sloid blue and solid yellow coming from the points, and on to the altenator side i have a single blue with red stripe wire, a negative (to ground to frame heavy duty) wire, and then the harness which has
1 light green with red stripe
1 blue with red stripe
1 solid green
3 soild yellow
1 white (looks off white due to years of heat fade)
1 empty slot
hope this helps
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: September 15, 2010, 04:47:02 PM »
It is certainly possible to run with the configuration you describe.
Did you have a question?
mystic_1
- John Augustus Shedd
Offline sky56
« Reply #3 on: September 15, 2010, 04:55:33 PM »
Sorry yes i did basically i understand that the link to the diagram i posted is for a kick only configuration and i would like to run a electric starter as well on days where im not up to several kicks. (granted i too agree that kicking a bike is 1oo times cooler than pushing a button)
So am i missing something with the diagram and the wires and what i am looking to do? Thanks
Offline Bodi
« Reply #4 on: September 15, 2010, 05:07:36 PM »
That diagram makes a few assumptions:
1 - you're using a car type ignition switch not the OEM one
2 - you're using a later DOHC type combined regulator/rectifier not the OEM separate regulator and rectifier
3 - battery power teleports to the ignition switch (no connection is shown, you should have a fused wire between battery + and the switch BAT connection)
The wires you care about in the engine connector are the 3 yellows, the green, and the white. The other two are the neutral switch and oil pressure switch.
3 yellows are the alternator 3 phase output, and go to your rectifier.
Green is ground to the alternator field coil.
White is power feed to the alternator field coil.
Minimum wiring would need a battery, regulator, and rectifier plus the on/off (or key) switch and a horn, headlight and tail light with brake light (and switch of course).
There's a good description for rewiring a bike using the "Santee" electrical box here: http://www.hondachopper.com/garage/santee_wiring_instructions/santee_wiring_instructions.pdf This includes the electric start but that's pretty easy to leave out. You have to plug the case hole properly if you remove the starter motor and you still need a battery (can be much smaller though). The Santee box was just an empty metal box you could buy made to fit the frame and drilled for components, you used your scavenged electrical stuff to stuff it and rewire the bike leaving minimum exposed wiring and electricals. The bikes I've seen with them had a generic automotive keyswitch with the usual off/acc/on/start positions and fired the electric start motor on "start".
The OEM keyswitch doesn't have any "ACC" terminal, just BAT and IGN and extra ones for the oddball tail light "parking light" stuff. If you use the OEM switch then IGN power goes to everything if you want to go extreme simplicity. Santee used the generic keyswitch because they were available at any auto parts store and, unlike the Honda one, mount easily in a round panel hole.
Offline sky56
« Reply #5 on: September 15, 2010, 05:31:48 PM »
here is the ignition switch im referring to so you guys see what i have
Offline Bodi
« Reply #6 on: September 16, 2010, 06:19:13 AM »
A fused wire from the battery (15A maybe) goes to the red wire. The black wire is you IGN power out to the bike's wiring. The other wires are for the parking light stuff, one of them will be connected to battery with the key in position three so make sure it is well insulated. There is no "ACC" wire.
Put the fuse as close to the battery as possible. The wire to it can pull full battery current if shorted to ground, and that can (and has) cause a fire immolating your ride.
The link I posted has all the wiring you need for what you want. It shows how to do it in a Santee box but regardless of where you put the components the wiring will be the same.
Offline sky56
« Reply #7 on: September 16, 2010, 06:25:16 AM »
Awesome everyone thanks for the help. That link is great thanks again.
KingCustomCycles.com
« Reply #8 on: September 16, 2010, 06:28:26 AM »
For you guys here only, if you want to buy one, it is available on ebay under propilot37 or on my website at kingCustomCycles.com Enjoy.
Offline mystic_1
  • 1970 CB750K
« Reply #9 on: September 16, 2010, 07:10:34 AM »
Nice diagram, King, thanks for sharing!
mystic_1
