Author Topic: Zorro's 1978 CB750 K8  (Read 37002 times)
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: Zorro's 1978 CB750 K8
« Reply #25 on: September 29, 2011, 10:55:23 PM »
Pods going to PU GZ tomorrow ;D  Well it was only a year old thread so why not dig in ;)
Offline lucky
« Reply #26 on: October 01, 2011, 12:47:54 PM »
I really do not like people that lie when selling a vehicle and play dumb.
"Probably needs a carb rebuild"
Probably needs a complete work up.
Did they tell you if their kids or friends worked on it too. Makes me mad.
Offline lucky
« Reply #27 on: October 02, 2011, 11:02:50 AM »
BTW...How did you get that heavy CB750 in the back of a pick up truck? WOW!
Offline lucky
« Reply #28 on: February 01, 2012, 02:33:29 PM »
I want to run pods but the pods I purchased were either too small
I know you rookies love the look of pods but i will guarantee  you that if its running well and smooth with the stock airbox then just leave it as it is, pods are mostly crap and will Never perform on a stock bike like the original airbox. Do a search of the forum and see for yourself. Most people only want pods for the look but they are a pain in the butt to tune and will never perform correctly right throughout the rev range, bogging, flat spots and a higher uneven idle are common.
Your speedo is also off an early 69-71 model 754, it may be worth selling on this site and using the money to get a correct replacement, your pipes are also off the 69-75 model K's, depending on the numbers on them, HM3400's for the early models and HM341's for the later 73-76 K's....
I disagree , and think pods will be just fine if you do the work to tune the bike properly.
If you do not believe me check out my video with a 1978 that has velocity stacks. runs perfect.
1978 Honda CB750 running
« Reply #29 on: February 01, 2012, 03:02:07 PM »
It is IMPOSSIBLE, for pods to work as effectively as the stock system for quite a few reason, it has been covered lots of times on this forum already, the stock velocity stacks were designed {engineered} to smooth out calm air supplied by the airbox to eliminate turbulence which directly effects the way the carbs work, the complete induction system was designed as a whole,  to work that way. There is a growing number of people that had your view that have eventually gone back to the stock system to find out simply that it is by far the best approach and easiest way to tune these bikes. Pods, by design, work at a particular rev range, most people experience this with either poor idle, jerky mid range and usually no problems up top because that is what pods were designed for. Anyway i am not going to go into any more detail here, this has been covered entirely by one of the resident engineers meticulously, do a search and read on..... Velocity stacks are not pods and you haven't even ridden your bike yet so that statement hold no credibility what so ever, stacks only , are use for racing applications mainly, or used to because they generally work best flat out and if you were up to date with all this you would realize that even motoGP bikes run airboxes with stacks.....I wonder why....
Use a freer flowing air filter in the stock system and put some holes in the bottom section of the airbox so it flows more and you will notice the difference and still be able to easily tune the bike. I will also say that some other makes of carbs will work reasonably with pods, the Honda carbs generally don't..... I also don't think it is very productive dragging up old posts and going over subjects that have already been flogged to death on the forum....
« Last Edit: February 01, 2012, 03:03:47 PM by Retro Rocket »
Offline lucky
« Reply #30 on: February 02, 2012, 03:56:26 PM »
Non rookies like pods too.
I wonder if you can use the stock rubber stacks with the pod over the outside?
« Last Edit: February 02, 2012, 04:00:06 PM by lucky »
« Reply #31 on: February 02, 2012, 05:36:54 PM »
I don't know the actual model number but K&N make a pod with a stack built in, that may help.....
Offline Zorro
« Reply #32 on: March 29, 2015, 09:14:56 AM »
BACK FROM THE DEAD!!!
So, my cafe project took a back seat to a few other hobbies.  I ended up getting married as well.  After 2 years of living with my wife, she kept asking "what are you gonna do with that old bike in the corner of the garage!?".   Finally, I decided to sell it. :(
I listed on craigslist and on this forum.  I got lots of interest but only one guy showed up to look at it - 02z06dave
We discussed the bike and me basically giving up on the build.  He showed me a few pics of a build he did.  He said he was going to build this one as well.  Dave basically said "you should let me buy it, or let me build it for you".  I said I'd consider both and we parted ways.
Now my wife knew I had someone coming to look at the bike.  She came home from work and asked if I had sold it.  I told her of my conversation with Dave and beat around the bush about me actually having him build it for me.   She gave me "the look".  Much to my surprise, she said "either sell it or build it, don't let it just sit there".  I love my wife :)
I frantically txt Dave to tell him of my decision - let him build it!  We met up and discussed plans and budget.   A couple weeks later, I took the bike to his place and we stripped it down to the frame in about an hour or so.  No turning back!
I've bought some parts and with the weather finally breaking in Ohio, we're about to really start getting in to the build.
I got some engine covers from Rusty Riders LLC on ebay (not pictured)
I got a seat from Bedlam Works
I got a tank from Legendary Motorcycles
I got a lighted seat hoop from Cognito Moto (not pictured).
Next two purchases are rear sets and hopefully and oil tank that I like.  I'd love a hidden one...and I'm open to suggestions.
Once I get these parts, we'll start modifying the frame and prepping it for powder coating, and painting the engine.
Anyway, I'm happy to have met Dave and revive this thread! Enjoy!!!
Offline Zorro
« Reply #33 on: June 10, 2015, 05:39:33 AM »
I've noticed most people name their project builds.  I never named mine.  However, after the flurry of spending I've done, I'm thinking of naming this one the "Budget Buster".  I probably have 75% of my parts purchased and 0% of my paint/powder.  Good thing for me that my wife and I don't share bank accounts :)
Anyway, here are some of the parts that have made their way to my house over the last couple months:
Rear Sets:
Oil Tank on Frame with seat and tank:
Black shocks with chrome springs:
Clip ons, speedo, tach, and fork brace:
Polished valve cover via 73Nancy:
I have some other parts waiting to be delivered but not pictured here:
Drilled rotors
Rear frame hoop
Frame kit from 754
I also have some parts that i didnt photo graph:
engine covers
new triple from cycle x
regulator/rectifier
rearset brackets
The head is also out to get honed slightly.  Once we have all the engine pieces back, we plan to paint it and build it while the frame is out for powder.
Almost to the fun part....
Online Stev-o
« Reply #34 on: June 10, 2015, 05:44:11 AM »
Looks like you are on a roll now.  Sometimes it just takes a kick in the ass from a buddy to get ya going!
« Reply #35 on: June 10, 2015, 07:57:59 AM »
Very nice bits. Looking forward to seeing it come together.
Offline Zorro
« Reply #36 on: June 13, 2015, 06:13:13 AM »
I got my rotors back from drilling by CycleX
We hope to have a rolling frame within the next week or so.
Offline Zorro
« Reply #37 on: June 15, 2015, 03:55:27 PM »
Frame kit from 754 and engine bolt kit arrived in the mail today.
Waiting on frame hoop from Cognito and valve cover.  Still need to buy many items.
Offline SKTP
« Reply #38 on: June 15, 2015, 06:26:57 PM »
holy moly!
2003 Ducati M800ie
1997 Honda CR-V
2004 Honda CR-V
1966 Honda S90
Offline Desert-SOHC
  • It's old
« Reply #39 on: June 15, 2015, 09:53:14 PM »
Any info on that oil bag? Who makes it?
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Zorro
02z06dave
« Reply #41 on: June 20, 2015, 01:59:29 PM »
That bike is going to look so disgusting when it's done! I can't wait to see it complete
Offline 73nancy
« Reply #42 on: June 22, 2015, 04:04:06 PM »
I love that gas tank!! Valve cover should be there very soon. You have a killer build going can't wait to see the finished product.
k1 cb750 cafe racer (aka Helter Skelter)
k6 cb750 stock daily rider project
k3 cb750 race bike 911 big bore, alum rods, 13:1, race cam other goodies
Offline Restoration Fan
  • My wife will never call me
« Reply #43 on: June 22, 2015, 06:57:07 PM »
This one should be good.  Subscribed.
Offline Zorro
« Reply #44 on: June 23, 2015, 06:20:03 PM »
Thanks all.  I got my polished valve cover today...looks fantastic.  I'll post pics tomorrow.
Offline Zorro
« Reply #45 on: June 24, 2015, 04:41:38 AM »
Here's a before pic of the valve cover:
and two after pics...polished by 73Nancy:
and
« Reply #46 on: June 24, 2015, 04:53:19 AM »
Nice!
« Reply #47 on: June 24, 2015, 07:12:51 AM »
That came out pretty damn fantastic.
Wobbly
« Reply #48 on: June 24, 2015, 07:30:31 AM »
Definitely a slight improvement over the original condition. :)
The bike is going to be pure eye candy. Well done.
« Reply #49 on: June 24, 2015, 09:56:29 AM »
Depending on you plan for finishes, you may want to clear powdercoat that valve cover.  Modern powdercoating does not yellow, and will save you from the chore of periodic polishing to keep that cover shiny.
