Author Topic: ready for a challenge?  (Read 1062 times)
Offline xedge4lifex
  • Trillz McGillz
« on: September 14, 2010, 05:14:06 PM »
76 cb550k
head was decked twice but within clearance
port and polish
lapped not cut valves
stock cam and gear
stock carbs
4-2 exhaust
good points
good condenser
new plugs
good wires
good coils
when reassembling the cam in the head the C notch didnt align perfectly with the level of the head ex: C-  instead of the 3 o clock portion of the notch meeting the level of the head, it was the 2 o clock position so the C notch was pitched forward a bit. now i struggled with the cam and gear and chain for about 2 hours tried 4 or 5 different ways to get the chain and cam and gear to line up at the 3 o clock position, and it was either the 2 o clock or 4 o clock position of the cam notch lining up with the level point of the head, so obviously after 2 hours of playing with it and not being able to achieve the 3 o clock position i figured it had to do with the head being decked and the clearance was enough to make the cam look out of spec, so i said bunk it. after assembly the tappets were adjusted to spec, carbs were rebuilt and super doooooper clean. with no pods or airbox the bike ran funky, so i timed it to the F mark on the timing plate which is 1/4 of an inch from the timing T mark. it ran, it revved, it hit redline. but it was sluggish, going up and coming back down. I tried vacuum syncing the carbs, i tried taking them off and just bench syncing them, i recleaned the carbs, the float height was checked and correct. reinstalled and the same problem, the bike will start, immediately rev up to 3k and just sound wrong and like its missing or like it doesnt have any guts. even after i installed my pods all the problems remained the same.
a friend of mine said lets just adjust it for the sake of doing it. on my timing plate there is the T then F then a 1-4 mark then two more notches. so if the T and F mark were at 12 o clock the other notches would be at about 2 o clock. after timing the bike to those other notches it almost seemed to run stronger. same issue, immediate rev up to 3k poor if any performance on a short ride, as soon as the idle drops below 3k the bike will die.
upon vacuum syncing the carbs the #4 carb seems to be this master carb where from all carbs being equal at 5psi at 3k any adjustment to give the #4 carb more psi raises the idle, adjustment to decrease the psi and the idle would drop down. i could get the bike to idle at 1100, however the #4 carb had about 3psi and all other carbs had about 6-7psi. the #4 carb also seems to have an issue where its getting gas, the cylinder is getting spark, #1 seems to be doing fine as the pipe is crazy hot, 2 and 3 are fine, but #4 is cold, it backfires from time to time, and it had this problem last year before i took the head off, but after a ride around the block/engine got warm #4 would come in strong and the bike would rip.
i have so far experimented with every possible combination of bench syncing, and timing, vacuum syncing, and timing, air screw adjustment, cleaning plugs, checking grounds and leads, point adjustment. everything short of taking the head off again.
im open to any suggestions, bestow your knowledge of awesome bike problems and fixits to me. because i feel like this could be stumping the best of them right now.
thanks!
Wake up, look up, there's a warmth up there
a reminder of peace, a reason to care.
Re: ready for a challenge?
« Reply #1 on: September 14, 2010, 05:21:31 PM »
I'm not real good with big posts, but I did not see a reference to an adjustable cam sprocket?  That would be the ticket, I think.
It seems to me maching the head would reduce the distance between the cam and the crank, throwing the chain timing off. An adjustable cam sprocket would allow you to time it correctly.
« Last Edit: September 14, 2010, 05:23:12 PM by MCRider »
« Reply #2 on: September 14, 2010, 05:28:56 PM »
Exactly
« Reply #3 on: September 14, 2010, 05:42:06 PM »
whew
Offline xedge4lifex
  • Trillz McGillz
« Reply #4 on: September 14, 2010, 11:25:07 PM »
adjustable cam sprocket eh?
havent come across any, or posts either. i have a 650 cam ive been itching to drop in as well so i may try both cams when i pull the rocker box tomorrow and see which can line up the best, maybe that way i can kill to poops with one poop.
thanks for the help!
ill post tomorrow and hopefully it will be magically fixed
Offline KB02
« Reply #5 on: September 15, 2010, 06:18:22 AM »
Exactly
Great minds think alike!! And I'm just happy that an adjustable ca, sprocket was my first thought,  too.   ;D
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
« Reply #6 on: September 15, 2010, 07:39:28 AM »
My bet is you'll still need the sprocket. The are regular fare on CB750s. Haven't seen one for a 500/550, but they can be easily made by machinists so inlcined. Drilling holes and/or slots to give you alternate places to place the sprocket.
You set the crank and cam where they are SUPPOSED to be, then turn the sprocket till you find the right combo.
Offline xedge4lifex
  • Trillz McGillz
« Reply #7 on: September 15, 2010, 05:25:28 PM »
i checked my #1 and 4 cylinders before pulling the rocker box today, zero compression in cylinder 4, plug looked brand new, only 25 psi in #1. so ill get the cam perfect and get my valves spot on tomorrow if it doesnt rain, and maybe ill have a running bike
thanks again everyone
Offline xedge4lifex
  • Trillz McGillz
« Reply #8 on: September 19, 2010, 03:59:52 PM »
basically i was off a tooth, the cam chain had been binding for some odd reason on the first installation. after being run or at least turned over enough the chain was looser, enough to meticulously lift up on it and slip it over a tooth. its back in the 3 o clock position and everything it toight and adjusted correctly.
reassembled and it rips!
thanks for the help.
