Author Topic: no reserve?  (Read 571 times)
Offline singedebile
no reserve?
« on: September 15, 2010, 01:45:48 PM »
Maybe I am missing something, but on my way home this morning I put 4 gal in my '75 cb550f which surprised me a bit as I had been ridding with the petcock arrow 'aiming' down at the "on" but I Just noticed my manual clearly shows "on" as being up..  Maybe the label is wrong on the petcock? (i just double double checked..  on is written on the bottom and res at the top).  I thought my tank was 3 gallon's "ON" with one in the reserve for a total of about four?
1975 cb550f super sport, 1976 Yamaha IT400, 1974 Suzuki T500
Offline betterthanurs916
Re: no reserve?
« Reply #1 on: September 15, 2010, 02:13:33 PM »
There should be an arrow cast onto the side of the petcock lever...this indicates the direction of operation.  So basically, the lever should cover the "on" label for standard operation and it should cover the "res" label for reserve operation.
1977 CB550F2
Offline singedebile
Re: no reserve?
« Reply #2 on: September 15, 2010, 02:22:49 PM »
which is what I assumed, but I am sure I put 4 gallons of gas in...  I guess I will try flipping it upside down and see if anything happens.
Offline Damfino
Re: no reserve?
« Reply #3 on: September 15, 2010, 02:32:44 PM »
Maybe the two inch plastic tube on your petcock inside the tank is missing or damaged? The tube is what feeds your fuel line. Once the fuel in your tank falls bellow the tube opening your engine should start to become fuel starved forcing you to switch to reserve.
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
