Author Topic: 500 crankcase w/ 550 top end  (Read 577 times)
Offline RatFink84
« on: September 15, 2010, 01:54:57 PM »
Will a cb500 crank case mate and work with a cb550 top end?
Offline fantino
Re: 500 crankcase w/ 550 top end
« Reply #1 on: September 15, 2010, 02:14:08 PM »
Yes. The only difference in the top end between 500s and 550s is the bore size, and also potentially a minor modification to the rocker shafts in the cam cover. Completely compatible, however.
The 550 bottom end is a better design, however. The transmission and clutch were reworked by Honda in light of some design flaws in the 500... Might be just as well off to find a whole 550 engine if you haven't put a bunch of money or custom work into your 500 bottom end.
Offline turboguzzi
« Reply #2 on: September 15, 2010, 02:18:25 PM »
+1
Offline number13
  • 1973 CB500, 2002 VT750DC
    • Sound Exchange
« Reply #3 on: September 15, 2010, 04:19:33 PM »
I've been running this configuration
for about 5 years. Works great.
Bikes parked out front mean good chicken-fried steak inside.
« Reply #4 on: September 15, 2010, 10:03:29 PM »
Some early 500's dont have big enough holes in the case for the barrel spigots but most do
