Author Topic: Kick starter delete  (Read 1318 times)
Offline anders288
Kick starter delete
« on: September 17, 2010, 09:01:17 AM »
Instead of doing any work today I made a kick starter delete. I'm not going to use the kick starter and I think it looks cleaner without it.
And as an added benefit it only weighs 25 grams.
Offline haggeo
Re: Kick starter delete
« Reply #1 on: September 17, 2010, 09:17:39 AM »
pretty clean.
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: September 17, 2010, 12:36:07 PM »
What will you do about the fact that the kick starter gear drives the oil pump, and that gear runs on the kick start shaft?
mystic_1
- John Augustus Shedd
Offline Flying J
« Reply #3 on: September 17, 2010, 12:53:23 PM »
thats what i was wondering. Most the kick start delete i have seen is just a neet little cap to cover the shaft.
Offline anders288
« Reply #4 on: September 17, 2010, 01:42:10 PM »
I didn't know the kick start shaft is also the support for the oil pump idler gear I am going to be removing it and will mod  or make a new shaft for the idler gear.
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: September 17, 2010, 02:03:08 PM »
It's too bad, your piece looks quite well made and is flush with the cover instead of protruding.
You could, perhaps, make a new longer piece that takes the place of the kick start shaft, but it would probably be quite complicated as you'd need to duplicate the shoulders etc on the kicker shaft that hold the gear in it's proper location.  I guess you could also cut down a stock kicker shaft to make it work.
mystic_1
Offline Flying J
« Reply #6 on: September 17, 2010, 04:48:23 PM »
this is what i have seen for 26.95
Offline anders288
« Reply #7 on: September 17, 2010, 05:26:05 PM »
I have seen them I want a flush look I have some ideas for my own clutch linkage cover to go with it.
Offline Flying J
« Reply #8 on: February 26, 2011, 09:11:54 PM »
back from the bottom of the pile. Im pretty sure im not going to be running a kicker. Could you cut the kicker shaft short and install a plug like his?
« Reply #9 on: February 26, 2011, 09:39:39 PM »
on a 500/550 you can remove the entire assembly,dont ruin the shaft!
