Author Topic: Suggest Jet size for 1976 Cb550 w/Cb650 cam/605/port os  (Read 2650 times)
Offline L.A. Nomad........
  • 1976 CB550 K
« on: September 17, 2010, 02:20:43 PM »
This is for a friend, ball park main jet sizes for CB550 with mods.
1976 CB550:
CB650 cam
605 big bore
opened and clean intake ports
has velocity stacks w/screens
electronic ignition
4-1 exhaust
Too hard to find in search. He currently has 100 main jets now. What are your thoughts and he's keeping the velocity stacks.
Thanks Eddie
I am a fuel-injected suicide machine! I am a rocker! I am a roller! [I’m an outta controller] I am the Chosen One! The Mighty and the Vengeance! Sent down  to strike the unroadworthy! I'm hotter  than a rolling dice!
  • 1976 CB550 K
Re: Suggest Jet size for 1976 Cb550 w/Cb650 cam/605/port os
« Reply #1 on: September 17, 2010, 04:03:17 PM »
Almost forgot!
We are at sea level, L.A. area. I know we'll have to mess around with the needle position and adjust. I know we might even have to use jet files..
He's gonna make a parts order soon, just need a range to start off with. He's gonna buy a couple of sets. Any suggestions?
Eddie  ???
« Reply #2 on: September 17, 2010, 05:33:28 PM »
Here's one mans experience...take it for what it's worth at 600 feet above sea level.
These are 77K PD carbs, originally with #42 pilots & 90 mains. Uses the stock plenum, no airbox, but a single large K&N filter.
Runs like a top with needle up one notch, 107.5 mains and with a tapered reamer enlarged pilot jet to #46 equivalent.
Good luck
Offline Will
« Reply #3 on: January 19, 2011, 03:15:14 PM »
Have you gotten a good tune on this CB550 yet?
I am just finishing a similar build; 600cc, 650cam, ported intake, pods, 4-1 high flow exhaust.
I'd be interested to hear where you ended up for jetting and needle position.
