Author Topic: No spark on 1 and 3  (Read 1020 times)
robd1017
No spark on 1 and 3
« on: September 17, 2010, 05:40:39 PM »
My 1974 CB750 has been sitting for two weeks while I painted the headlight bucket and controls.  I had a heck of a time getting it to start today and once it did, it didn't sound right.  I shut off the engine and on a hunch I felt the exhaust and pipes 1 and 3 weren't hot.  I pulled the spark plugs and checked for a spark and of course 1 and 3 had no spark.  It seems like a coil has gone bad, but I'm not sure how that happened since the bike was just sitting in my garage.  But before I buy another coil, is there anything else that could be causing this problem?
Thanks,
Rob
Offline Calflash
Re: No spark on 1 and 3
« Reply #1 on: September 17, 2010, 05:59:34 PM »
Do you have power TO the coil? Check your connections. If they are good, swap coils and see what happens.
Calflash
US Army
Nam 66-67
80 CB650
Markcb750
« Reply #2 on: September 17, 2010, 06:08:58 PM »
1 & 3 are separate coils, ar you sure it is not 1 & 4 (the outer pipes) or 2 & 3 (the inner pipes).
when did you perform your last 3000mi tune up?
Offline 2wheels
« Reply #3 on: September 17, 2010, 06:15:17 PM »
how's the point gaps?
1970 CB750 K0 (I can't believe I tossed my duck tail seat in the trash 30 years ago)
« Reply #4 on: September 17, 2010, 08:15:24 PM »
Check your spark plug caps with an ohmmeter, mine went bad.
And give it a full "3000 mile" tune up.
Offline nancy
  • CB750 K2'ish - SOLD!! Triumph Sprint GT2011
  • No worries matey..
« Reply #5 on: September 18, 2010, 03:55:15 PM »
My caps too. I had 3 showing 5ohms and 1 showing 9.75. Should all be around 5ohms. Higher the number means the WORSE they are.
Offline MoMo
  • Ride like you're invisible
« Reply #6 on: September 18, 2010, 06:24:12 PM »
Have you made sure the caps are screwed tightly to the wires? Frequently  I need to trim the wire back a bit and then rescrew the cap back on. Good luck, Larry
Offline Spanner 1
« Reply #7 on: September 18, 2010, 07:16:51 PM »
OP... couple of Q's... .. were the #1 and #3 plugs wet or dry when you took them out and how did you test for spark?,,,,, I think 1 and 3 float needles are stuck and dry bowls...... put bike on mainstand, turn-on gas, tap each float bowl with a screwdriver handle, wait 30 seconds, then try to start bike. Stuck floats/needles can be common esp. if the bike is left on it's sidestand IMO.
