Author Topic: CB550 fuel leak between carbs, common?  (Read 10351 times)
Offline j squared
  • www.iliketogofast.com
    • ILikeToGoFast
« on: September 18, 2010, 07:03:10 PM »
I ran my bike for the first time today and noticed I had a fairly steady fuel leak coming from both sides of the bike, up above the float bowls.  After getting it home and looking at it while it was idling I am pretty sure it is leaking at the T where the two fuel lines come in and connect to the carbs, between 1&2 and 3&4.
I circled where I think the leak is coming from, maybe bad o-rings?
Is this a pretty common place for leaks?  Im asking because I want to be 100% sure its not leaking where the fuel line meets the T, even though I checked and rechecked it Id rather not have to rebuild these carbs if at all possible :(  Just got this thing on the road and of course something like this happens!!  Argh.
Anyway, I did a few searches and didnt see anything specific to this fitting, if anyone could offer some advice that would be awesome!
« Last Edit: September 18, 2010, 07:09:57 PM by j squared »
Re: CB550 fuel leak between carbs, common?
« Reply #1 on: September 18, 2010, 07:07:50 PM »
I have a 550 and have not heard of this issue.
Offline fmctm1sw
« Reply #2 on: September 18, 2010, 07:59:35 PM »
I had to put new o rings on those on my 350F after (naturally) I had the rack stripped to clean the carbs.  I buy fuel resistant o rings like that at Napa...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline Raef
« Reply #3 on: September 18, 2010, 09:18:07 PM »
I don't know how common it is but i have had to replace them before. I just used some o-rings out of one of those o-ring kits with the assorted sizes.
It's a pain in the rear, but the job can be done in a day.
Offline Deltarider
« Reply #4 on: September 18, 2010, 11:36:02 PM »
It's not common. Have you used hostile fluids by any chance?
Out of curiosity: do your T-joints have double O-rings on each side or just a single?
CB500K2-ED Excel black
« Reply #5 on: September 19, 2010, 02:03:48 AM »
Its very rare unless they have been stripped and damaged, more common is to put a nick in the pipenpushing it on
KingCustomCycles.com
« Reply #6 on: September 19, 2010, 03:56:49 AM »
The seals dry out and may reseal in a day or two with exposure to fuel.  Also, modern 1/4" fuel line is not what was installed originally on these bikes.  It is larger than the I.D. original.  I like to use a wrap of aircraft safety wire (brass) as a clamp for the main fuel lines at the carbs.  There is not enough room for screw clamps and the wire looks pretty old school.
Offline 736cc
« Reply #7 on: September 19, 2010, 05:24:56 AM »
. You cannot avoid the fix because the leaking won't stop anytime petcock is open. On CB750's u need to remove carbs and seperate them from the rack to get to the T's. Those o-rings need to be fuel resistant and very hard to source the exact size in mm. Somebody on ebay was selling them a while ago; maybe search this forumn under carb T's o-rings
Offline Mavryk03
  • it's a project 75 Honda cb550k1 cafe, this will never be done
« Reply #8 on: September 19, 2010, 06:34:14 AM »
On my cb550f when i rebuilt the carbs i out new o-rings on lines yours a prob just old and crusty, it is a pain to replace them but it's worth it good luck ;D
Avi: why do they call him boris the bullet dodger?
Bullet tooth tony: Cause he dodges bullets Avi
Got to love Snatch lol
Offline Kevin400F
« Reply #9 on: September 19, 2010, 09:33:56 AM »
1.9mm cross-section x 8mm i.d.   Buna-N 70 Durometer.
I have plenty on hand, if you would like a set.  You'll need 8 rings (four per tee).
Send me a PM on the Forum here, or shoot me an e-mail at kthunter01@sbcglobal.net
Offline j squared
    • ILikeToGoFast
« Reply #10 on: September 19, 2010, 06:03:47 PM »
Thanks for the help everyone, I took a look today and I think one side has dried up but the other side is still leaking pretty bad.  I figure its not going away and might as well fix it now rather than worry about it later.  Ive never done any carb work before so no better way to get my feet wet I guess :)
So, if the rest of the carbs dont appear to be leaking, do you guys think its worth doing a complete rebuild to clean them out while I have them off?  Ive taken them off before and don't think its too hard, but I hear once you separate them from the rack thats the worst part, reassembly-wise.  Might be worth it to see whats in there after who knows how long since a bath.
I'll totally take you up on that, thanks man!!  PMing you now.
Offline Raef
« Reply #11 on: September 19, 2010, 06:18:47 PM »
I would at least pull the bowls off and take a look and check the float heights, valve seats idol jets
Mark
Offline Deltarider
« Reply #12 on: September 21, 2010, 01:32:03 PM »
Are you sure it's not leaking from between the fuel hose and the joint. That is common, as people sometimes use wider (6mm) than the 5,5 mm ID hose.
Offline j squared
    • ILikeToGoFast
« Reply #13 on: September 21, 2010, 01:44:17 PM »
I checked it twice but I am definitely going to check it again before I make the call.  The OP had some non-OEM fuel line on there so it may be too big.
I'll see about getting a small zip-tie on there to see if it stops, or using some brass wire like someone mentioned.  If that all fails, maybe get some new hose and run it back on there but Im sure getting it on that nipple with the carbs installed is not easy (maybe not possible).
Offline Deltarider
« Reply #14 on: September 21, 2010, 01:49:39 PM »
When not sure where it leaks powdering the suspect spots with talcum powder can help to identify. Yes, it can be hard to shove the tube over the nipple. A bit of WD-40 sprayed inside the tube-end can help.
Offline j squared
    • ILikeToGoFast
« Reply #15 on: September 21, 2010, 01:57:54 PM »
Im going to take a closer look sometime this week and see if I can pinpoint it for sure.  Where the T fitting is and where the lines connect to the T are so close though it was really tough to see before, Ill try some powder though and see if it helps.
Offline j squared
    • ILikeToGoFast
« Reply #16 on: September 22, 2010, 02:34:26 PM »
Just an update for anyone paying attention :)  Found one side is still leaking after a few days of starting it after work and letting it idle for 5-10 minutes.  Whats more, last night I started getting really bad float overflow on at least two carbs, huge puddle of gas under the bike.
Figure its time to pull these carbs and crack the bowls to see what is up in there, and also to take a closer look at the fuel line T's to see if I can spot the leak.  if nothing else I will be able to get the fuel lines attached properly with the carbs off and more room to work.
Side question: at what point should I think about resynching the carbs?  I have read some posts that say you should synch them any time you pull them off the bike, and that seems a little extreme.  I'd rather not have to buy a synch tool right now although I do want to get one eventually.  Just have other things that need to come first this month.
Edit:  One more question, if there any harm in filling the carbs with gas while they are off the bike to look for a leak and check the float function?
« Last Edit: September 22, 2010, 02:36:11 PM by j squared »
« Reply #17 on: September 22, 2010, 03:15:25 PM »
no synch required unless you change something that effects airflow.  It is a great idea to test the carbs for leaks off the bike.  I put a can of gas 5 feet above the rack, level it on the bench with a 2x4 under the throats and look for drips.  That step saves hours of pulling and reinstalling on a drip that is hard to fix.
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #18 on: September 22, 2010, 03:33:09 PM »
Sounds like you will be pulling the carbs. Cleaning and new o-rings throughout is not a bad thing. Prevents further fuel leaking in the future. O-rings dry out, get brittle and crack. All of mine inside my carbs were just that. I feel better replacing and thoroughly cleaning them. The bike runs way better. You can check/set your floats, make sure your needles are set correctly, and bench sink the carbs and drive it that way until you can afford a syncing tool. If you get the Honda OEM carb gasket kit you get everything you need.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline j squared
    • ILikeToGoFast
« Reply #19 on: September 22, 2010, 03:46:44 PM »
Thanks for the tips guys, you guys rock.  Going to be diving in tonight, once I get a closer look I will make the rebuild call but I'll probably end up doing it I'm thinking.  Just hate to have the bike down again for a few weeks after a total ride time of 10 minutes so far :(
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #20 on: September 22, 2010, 03:54:39 PM »
Get a gasket kit first then download the manual section on carbs and articles from the FAQ section about rebuilding and removing carbs. Also your blow up diagram up above will help a lot too. If I can do it, anybody can do it  ;D
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline j squared
    • ILikeToGoFast
« Reply #21 on: September 22, 2010, 09:42:24 PM »
Well I pulled the carbs off and drained them, quite a bit of rust sediment came out of the float drain screws so I was expecting the float bowls to be really bad.  Pulled them off and they were pretty much immaculate haha.  Thanks, PO.  Cleaned some rust from the bottom and checked the tank, sure enough some rust had accumulated at the bottom between draining it over the summer and now.  Guess some clean up is in order.
Gave the float bowls and the jets a blast of carb cleaner and compressed air, pushed the fuel lines on the T's better and wrapped a small zip-tie around each line and reinstalled the carbs. Also checked the float heights and they weemed about just right.  Im going to run it tomorrow and see what happens, Im thinking (hoping) it should be OK.  If I have to pull them off again and rebuild so be it, I'll jump off that bridge when it comes haha.
Offline Deltarider
« Reply #22 on: September 22, 2010, 11:26:10 PM »
If you remove the carbs from the bike and/or remove the float bowls for inspection there's NO need to synchronize afterwards. (To much syncing going on in this forum, if you ask me.)
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #23 on: September 23, 2010, 08:49:37 AM »
Sounds like syncing fixes a lot of problems on this board as well. If he doesn't know if they are synced then it's time well spent.
1974 CB360T
2015 BMW F700GS
  __o
_- \_<,
Offline j squared
    • ILikeToGoFast
« Reply #24 on: September 23, 2010, 11:23:50 AM »
yeah it definitely wouldnt hurt and I probably would if the carbs ended up being dirty or if the bike ran poorly before.  Carbs were just cleaned it looks like and the bike ran great before it started leaking so Im guessing the PO just had them serviced/sync'd pretty recently before selling it.
Meant to take a look at the jetting since I have a 4-2, see if maybe he got it tuned for them or not.
