Author Topic: ok... throttle turns backwards????? SERIOUSLY!!!!!!!  (Read 988 times)
Offline kopptl
« on: September 19, 2010, 05:28:38 PM »
cb750k.
when i let go of the throttle, it idles, but i can take my hand and turn the throttle slightly forwward a ways, and the idle goes down.  :o but when i look at the sides, thaey dont seem to be ,moving at akll...
im stumped...
Re: ok... throttle turns backwards????? SERIOUSLY!!!!!!!
« Reply #1 on: September 19, 2010, 05:43:01 PM »
cb750k.
im stumped...
Your cables are not adjusted quite right. IMO. The A cable (pull to open) should be adjusted so that the full range of carb slide movement is attained by leting go of the throttle and letting the return spring do its thing. Lowest idle to wide open.
The B cable (pull to close) is just along for the ride as a safety should the return spring fail to overcome the A cable. If the carb slides are not hitting rock bottom with the A cable relaxed, then turning the throttle backwards activating the B cable will pull them a tiny bit more closed, and it may not be perceptible.
A bad job of synchronization can result in the slides not hitting rock bottom and then you can do what you describe. Rock bottom may not be the same for each slide. One slide should be at rock bottom and you sink to that.
Others here are more expert at sinking than I am and I defer.
Offline kopptl
« Reply #2 on: September 19, 2010, 08:46:42 PM »
could removing the push cable work?
« Reply #3 on: September 19, 2010, 08:58:52 PM »
Not sure about the question. Work? in what way?
You may loosen it completely, or remove it to assess the action of the A cable. Once the A cable is functioning properly you can adjust the B cable back into play.
Removing the B cable entirely,permanently requires a second thought as it is a safety issue. And the throttle should work properly with all hardware intact.
Offline cobra2411
« Reply #4 on: September 19, 2010, 09:03:27 PM »
Check the adjustment of the cables. I had this happen and I had the A cable too tight. You will still be able to turn the throttle backward but it shouldn't lower the idle. If you look at the bell crank there is a spring that allows the B cable side to move a little before it works on the A cable side.
