Author Topic: cb550 seized? compresion questions  (Read 1422 times)
weissmatts
« on: September 20, 2010, 08:22:59 PM »
I have a 1978 cb 550k that shut down on me mid ride, I think the engine seized..... I want rebuild the engine. Where do I start?
Offline Logan80
Re: cb550 seized? compresion questions
« Reply #1 on: September 20, 2010, 08:38:51 PM »
You think it seized, or it did seize?
It should be fairly easy to find out. Push the starter button and/or move the kickstarter peddle.
I guess start there before jumping into a rebuild...
Offline Brian G
« Reply #2 on: September 20, 2010, 08:50:59 PM »
Where do I start?
Oh dear...., where indeed??
Can you turn the engine - either with the starter motor or the kickstarter? If you can, the engine has probably not seized. (I say 'probably' because they can seize then free up after they've cooled.)
If the engine turns, there are two things which will stop it from running - lack of fuel or lack of spark. It remains to find out which one of these is missing.
You say the engine stopped in mid-ride? My (admittedly non-educated) guess would be an ignition failure (a fuel starvation problem would probably show itself as a loss of power and an intermittent surging/cutout before it failed completely. Try removing a sparkplug to see if there is a spark at the electrode when you ground the plug against the cylinder head and crank the engine.
I'm thinking that you need to do some basic troubleshooting here. I suspect (by the number of your forum posts) that you're a newcomer to SOHC Honda 4's - Welcome, friend, to the show that never ends  ;D
Find a manual (there's a link at the top of this forum, or you can buy a Clymer or Haynes manual) and go through the troubleshooting section. Then get back to us with your ideas as to what's amiss. We'll be happy to help if we can  ;)
Regards,
1975 Honda CB400F
1978 Honda CB550K
1979 Honda CBX
1969 BSA Rocket 3
1976 Kawasaki KH400
2008 Kawasaki C14 Concours
weissmatts
« Reply #3 on: September 20, 2010, 10:15:32 PM »
well I pulled off the pipes and used the kick start to see if the valves move and they don't...... so I know that cant be good.
and I don't hear the pistons moving nor see the valves moving
Offline Logan80
« Reply #4 on: September 20, 2010, 10:21:03 PM »
Does the kickstarter move? Can you feel compression as the engine rotates?
weissmatts
« Reply #5 on: September 20, 2010, 10:29:21 PM »
yah it moves, I can only hear air from the carb box when I use the kick start though
Offline parm
« Reply #6 on: September 20, 2010, 10:34:36 PM »
maybe your cam chain broke and thats why you dont see the valves moving
weissmatts
« Reply #7 on: September 20, 2010, 10:42:07 PM »
I had a feeling it was that but I wasn't positive, any advice on how to replace that?
Offline scunny
  • don't call me expert
« Reply #8 on: September 20, 2010, 10:46:31 PM »
at the least, take off the rocker cover and see if the cam chain has broken or the sprocket came off.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
weissmatts
« Reply #9 on: September 20, 2010, 11:06:27 PM »
Cool i'll give that a try, you guys have been a real help. My first time on this website has proved really affective
