Author Topic: Carb stix v. Carbmate v. Twinmax v. CarbTune...  (Read 14674 times)
Offline historicjake
« on: March 03, 2006, 07:34:18 PM »
Hate to bring up the subject of carb syncing but it is that time of year...weather turning, birds singing...
I have for years used a carb stick with mercury with frustrating success by feel that now it is time to move on.  Always having to be so carefull with the thing drove me nuts and the restrictor holes were not all the same size causing bad readings.  Having kids and a wife and mercury in one household is too much, so one has to go, see you later carb stick.
I'm looking for real world experience with other tools, from gauges to electronics,
Are the expensive ones worth it?  Just take it to a shop and let them do it?  Do it by ear or by exhaust pressure?
By answering you may bring on riding season a bit sooner.
Offline GroovieGhoulie
  • I have to return some videotapes.
Re: Carb stix v. Carbmate v. Twinmax v. CarbTune...
« Reply #1 on: March 03, 2006, 08:18:14 PM »
I bought a carbtune and love it.  Easy to use, accurate and not too expensive.
cd811
« Reply #2 on: March 03, 2006, 08:33:41 PM »
good thread...
I got to but something myself...
what is not too expensive?
« Reply #3 on: March 03, 2006, 08:49:12 PM »
good thread...
I paid about a hundred bucks for the carbtune, hoses, fittings, buffers, carry case (Necessary, IMO), adjustment tool.
« Reply #4 on: March 03, 2006, 11:27:39 PM »
I bought gauges (4 dials) in 1975 for $50.  I didn't use them again for 5-7 years.  Later, when I began collecting bikes, I used them on each one.  And, I was glad to have them.
If I only had one bike and never planed to work on more of them, I'd let the shop do it.
Oh, who am I kidding?  I love tools and fixing it myself too much to have a shop work on my bike. ::)
I don't believe you can do a proper sync job by ear or by exhaust pressure.  Maybe on a two cylinder engine, but not four.
Offline ofreen
« Reply #5 on: March 04, 2006, 12:07:54 AM »
The way I've always looked at it is this - You can pay the shop to do it (and hope they do it right), or you can pay for the tool and do it yourself.  And when you are done, you still have the tool.
Greg
'75 CB750F
Offline Steve F
« Reply #6 on: March 04, 2006, 02:28:47 AM »
Amen to that!  I have the 4 gauge (mechanical gauges) setup myself.  Never had anything else, but I'm satisfied with it.  I did find it necessary to calibrate them before I use them by simply attaching all of the gauges to a common vacuum source and adjust them to read the same across all four.  I use a vacuum generator on the compressed air line to make the vacuum for calibration.  What's nice about the mechanical gauges is you can lay them on the floor, across the handlebars, turn them everywhich way and not worry about spilling some toxic substance.  8)
kaysystems
« Reply #7 on: March 04, 2006, 06:14:40 AM »
I used to use the 4 guage setup, until one day when I was having trouble getting resulte & swapped the tubes on 1 & 4. Different readings. After some  investigating I found that the 4 guages were giving different readings, even though they all started exactly at zero.
I bought a carbtune & never looked back. You can even drop it without worry
David
« Reply #8 on: March 04, 2006, 08:55:57 AM »
I've got gauges too and prefer them. It is wise though to check each gauge, I have 1 @-1" and 1@+1", but just marked the face accordingly to remind me.
« Reply #9 on: March 04, 2006, 10:32:05 AM »
I use a Mity-vac and a 5 way manifold to check my guages before use.  About ten years ago, they starting behaving oddly and sticking.  The mechanical movements inside the dial were greased and that grease had hardened.  A bit of a solvent flush and some Lubriplate had them all working predictably again.
Did I mention I bought these new in 1975?  So, they've cost me  $1.61 per year to own and use...so far.  Okay, if you add in the cost of the Mity-Vac and lube, it was maybe $2.50 per year.  But, that doesn't include storage costs.
I wonder what percentage of my house I should attribute to that tool's storage?  Then again, my house is worth nearly 5 times what I paid for it.  So, what ever the storage costs, it would be a negative number when applied to tool storage.
Um...What was the question?   ;D
cd811
« Reply #10 on: March 05, 2006, 10:34:57 AM »
ok... so where are you guys buying these tools?
I've put it off long enough :D
« Reply #11 on: March 05, 2006, 11:24:47 AM »
Here's what I'm talking about, not nesssessarily the lowest price...
http://www.aerostich.com/catalog/US/Electrical-p-1-c-270.html
http://www.carbtune.com/
http://www.motionpro.com/parts/tools/product/deluxe_carb_tuner/
Motion pro has a cheaper version...
Hasn't anyone tried the all electronic systems...perhaps in a shop?  And how does a shop do it ?  Or for that matter, racers???
cd811
« Reply #12 on: March 05, 2006, 11:43:14 AM »
the carbtune looks like the deal...I've used the motionpro set-up many times...the carbtune looks easier to use(and a better deal)
what about the dial guage set-ups?
Offline Jay B
« Reply #13 on: March 05, 2006, 05:40:59 PM »
I've been using a twinmax for about 5 years now. I like it a lot. I think they are about $100 including fittings to adapt to the vacuum ports. You can adjust the sensitivity up or down, highest is ridiculously sensative. My Oilhead BMW has a wonky bellcrank/two cable system to run the throttle bodies. It's very sensative to throttle synch, and needs to be done pretty often so I wanted something accurate without any mercury to spill. If anyone's interested I think I have the phone number someplace still.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline itsahonda4
    • www.wfomodels.com
« Reply #14 on: March 21, 2019, 01:55:02 PM »
OK - so I was given a set of carbstix but the mercury appears to be low....
Where do I find liquid mercury? Certainly not home depot or wallymart I suspect.....
Al
Offline Tom in Newcastle......Ontario
  • Newcastle Ontario
« Reply #15 on: March 21, 2019, 02:01:43 PM »
Al
Do you know a HVAC person....some thermostats have mercury switches in glass tubes....put it in a zip lock bag to prevent the stuff from going all over......just be careful as we all know mercury is not the healthiest crap........
1978 cb 550k......stock,my first re-build
Loud pipes suck.......
If you buy something.........pay for it !
If you sell something .......ship it !
If you say you are going to do something......do it !
If you have a question about something......ask it !
When the seller answers ........let him know whether you still want it or not !
If you receive something .....let the seller know you got it !
If you get something and are happy/un happy with it .....let the giver/seller know !
If you have any kind of issue,shipping/receiving/quality/price/shipping charges etc !
Communicate
Offline Mooshie
« Reply #16 on: March 21, 2019, 02:34:48 PM »
1976 CB550F
Standard disclaimer: Remember I am just a girl--so be nice fellows!
Offline pjlogue
« Reply #17 on: March 21, 2019, 04:08:33 PM »
I think the carbtune is the best I have tried.  Very simple, rugged, accurate, reasonably priced and easy to use.  The only drawback is the snubber tube that came with it should have been longer.  I cut the tube in 4 exact equal lengths and I would like them to be a tad longer to further reduce flutter.
-P.
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #18 on: March 21, 2019, 08:57:33 PM »
Finding a carbtune at a swap was the best addition to the toolbox.
Use it in any bike with more than 1 carburetor.
Hell, it even works upside down!
Offline brewsky
« Reply #19 on: March 22, 2019, 02:43:10 AM »
What about a single cylinder with twin carbs?
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline toomanybikes
« Reply #20 on: March 22, 2019, 02:56:02 AM »
Thanks all. I've been using a DIY system for a few years now that works ~OK on twins, but with four 4-cyl bikes currently in the stable it's time for a real tool. Carbtune it is
current stable, always subject to change ...
'80 CB650C
'82 GL500
'81 Suzi GS450L (cafe)
'03 Suzi SV650
'07 Yamaha VStar 1100
'10 Bonnie
'14 VFR800
« Reply #21 on: March 22, 2019, 05:24:00 AM »
-P.
  Did your carbtune come with the the inline restrictors and were they put in at the proper spots ?  Don't have flutter problems with mine.
Offline pjlogue
« Reply #22 on: March 22, 2019, 05:56:10 AM »
-P.
Yes.  The thin, very small bore tube that came with the kit, I cut into 4 equal length pieces.  These were put in line with the rubber tube and about 4" from the end where it connects to the carb adapter tubes at the carbs.  The flutter isn't real bad but I'd like to see it less.  When the bike is in low idle the flutter is annoying.  I guess I could either get longer snubber tubes or longer snubber to gauge tubes so they have more "capacitance"
-P.
Offline carnivorous chicken
« Reply #23 on: March 22, 2019, 10:44:12 AM »
I used a mercury tool for years and liked it, but switched to a Morgan carbtune and won't go back.
I know some people say they are OK, but I had a Motion Pro tool with the blue liquid, and it developed bubbles and wasn't accurate.
Offline Kelly E
  • Geriatric Hooligan
« Reply #24 on: March 22, 2019, 09:06:00 PM »
I have a DigiSync electronic manometer with a built in tach. Mine is the four channel model and is very accurate and comes with connectors. It uses the vacuum pulses to determine RPM's. It doesn't need any restricters and just needs to stay above the carbs. On my V4 Sabre it is really easy to hook up but I haven't used it on an inline 4 yet, the 400F went home and my 550 isn't done yet. It is minor surgery to hook up to the Concours.
1978 Kawasaki KL 250
1980 Suzuki GS 1100E
1983 Honda CB 1100F
1984 Honda VF 700S Sabre
1990 Moto Guzzi 1000 Le Mans
2005 Harley Davidson Fat Boy
