Author Topic: start button / guages wired together?  (Read 1275 times)
Offline 1974blaze
« on: September 25, 2010, 11:32:34 AM »
anyone know if the gauges (brown/white) need to be connected for the start button to work on a 74 cb750? i removed the gauges (while doing a bunch of stuff) and everything seems good now that it's back together but no electric start.  just wondering if i need to check my other connections or if it's just the misssing gauges, like maybe the switch grounds through the same circuit or something.
thanks.
bollingball
Re: start button / guages wired together?
« Reply #1 on: September 26, 2010, 04:24:43 PM »
Does back together mean the gauges are back on? Even if not the four little light don't have any thing to do with start circuit I would look first to see if you left a GRD. wire off somewhere. Then start going through the start circuit I have a K8 I think they are not the same I will look at the K4 and get back to you.
Offline 1974blaze
« Reply #2 on: September 27, 2010, 09:05:32 AM »
thanks for checking. no the gauges are not back on.  doesn't look like a ground is missing, but i will triple check for sure.  the lights are wired separate and are working fine, i made my own led set up for that.  in fact everything else is working great, just the electric start is "off".  i will put the gauges back eventually, or at least one of them and we'll see.  i have a wiring color chart that seems to suggest that the brown/white wire of the gauges is somehow involved in the ignition circuit.
 anyone else have thoughts?
KingCustomCycles.com
« Reply #3 on: September 27, 2010, 09:24:19 AM »
Does this bike have the headlight cut-off wire when the start button is engaged?  If so, the light wiring you have done may have disabled that.  Check your schematic online here or at oldmanhonda.com
Offline 1974blaze
« Reply #4 on: September 27, 2010, 09:33:35 AM »
i'll look into that.  i didn't do the initial wiring, so it's possible.  i honestly can't remember, but i kinda feel like yes the headlight shuts off at start??..
bollingball
« Reply #5 on: September 27, 2010, 11:17:25 AM »
Will it kick start ? have you checked for power on both sides of the 15 amp fuse ? Turn your kill sw. back and forth a few times. If none of that helps report back and will start going thru the print. Has any thing but the LED's been change?
Offline 1974blaze
« Reply #6 on: September 27, 2010, 11:41:36 AM »
kick starts in one kick.  everything else good too. :D
