Author Topic: What is UP with BENDING float tangs?  (Read 3398 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: September 26, 2010, 03:39:47 PM »
There has has GOT to be a better way to set float heights than bending the tangs.
How imprecise is that?
Totally dives me nuts...
Is there any trick 70s after market dodad that has a more elegant adjusting mechanism? Or another method? Anything?
Offline mycb750k6
  • "res ipsa loquitur"
  • Rocketman
    • photobucket albums
Re: What is UP with BENDING float tangs?
« Reply #1 on: September 26, 2010, 03:48:59 PM »
Bend, measure. Bend, measure again. Bend back, measure. Bend back some more and measure again. Repeat until correct. After a while you'll be saying how easy it is. :)
« Reply #2 on: September 26, 2010, 04:40:54 PM »
There have been tools to do the measuring, but you have to still bend the tangs. I suppose you could machine in some adjustable stops so that you could adjust them externally.
Offline Frostyboy
  • Retired: Never was an
  • Circa 1951
« Reply #3 on: September 26, 2010, 04:54:59 PM »
Short answer: Unfortunately no.  :(
Last year I joined a support group for procrastinators.
We haven't met yet.
[CB550F1]
Offline Old Scrambler
« Reply #4 on: September 26, 2010, 05:36:35 PM »
If you have stock parts there should be no reason to bend the tangs!  Clean original parts are usually better than replacement parts - especially if they are not HONDA parts.
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline mycb750k6
  • Rocketman
« Reply #5 on: September 26, 2010, 06:17:16 PM »
I have found that all the carbs I have bought recently needed adjustment. One should at least check to avoid problems later.
I like the idea of an adjuster. Sorta like the throttle screw. Just thread a small adjuster screw  :-[in the tang and adjust with a needle nose without removing the float.
And maybe there should be no reason to adjust the tangs, but for some reason there seems to be a lot of reasons with the ones I've collected. People can't leave them alone. The chances of a float having been adjusted in a forty year span is probably good. And it seems that when the float valve starts to go and gets spongy and weak, it doesn't hold up against the float pressure as it once did so another adjustment. This stuff wears out and needs maintenance. And I've also found the little pin that sticks out of the float valve is different in length depending on the source - so yet another adjustment.
Offline Spanner 1
« Reply #6 on: September 26, 2010, 09:29:19 PM »
Lots of tab/tang/float threads here.... having read them all  ??? I think when the correct float 'height' is achieved with the tab just 'resting' on the float needle ball there are 2 things that need to be looked at 1. that the tab is now 90 degrees to the float needle in it's new position and 2. that the tab (upper ) surface to the teeny float ball is completely smooth ( polished ).... if everyone did those 2 things I think the Forum would be missing a lot of carb. prob. posts  ;) ;D
Offline Gordon
  • 750K1, 550K2
« Reply #7 on: September 27, 2010, 12:30:59 AM »
The precision is in how well you measure, not the method of adjustment.
« Reply #8 on: September 27, 2010, 02:05:08 AM »
billions of carbs of all types have to have floats bent to set them,excepting some holleys,use your finnese.
« Reply #9 on: September 27, 2010, 06:59:20 AM »
+100
Offline drones76
« Reply #10 on: September 27, 2010, 07:28:16 AM »
I checked my carbs this weekend using the vinyl tube in the drain hole method.  One level was right at the gasket line and the other was above it.  I removed the carbs and measured.  The one that was higher needed to be adjusted.  I adjusted it and both measured correctly.  It brought it down a bit but not quite to where the other is.  So according to the book, they are in spec.  My question is where exactly should the level be for a static test as outlined above?
1976 CB360
And I do realize this bike is not a SOHC4.  I am just asking in general if there is a level that should be in the floats.
« Last Edit: September 27, 2010, 07:31:41 AM by drones76 »
1974 Norton Commando Roadster
1980 Goldwing Interstate
1975 Kawasaki KZ400D
Looking for a SOHC-4
« Reply #11 on: September 27, 2010, 07:43:35 AM »
4mm below bowl gasket seam.
Offline grumpy
« Reply #12 on: September 27, 2010, 07:57:57 AM »
There's the problem. I have digital calipers that are accurate to .001in but bending the tangs is like shooting baskets in the dark... sure, you might get it eventually....
Is that for other bikes as well?
Offline Gordon
  • 750K1, 550K2
« Reply #13 on: September 27, 2010, 08:07:42 AM »
I guess I just think of it in the same way as adjusting valves, timing, points gap, idle mix screws, brakes, chain tension, etc.  You make a small adjustment, measure, and if it's not enough you make another small adjustment, measure and continue until it's right.
Offline grumpy
« Reply #14 on: September 27, 2010, 08:10:27 AM »
Yeah, I know. Finesse and zen...
But dammit I'm an American!!! It all about ME, and I want it NOW!!! And I don't want to have to learn anything in the process!!!!!! ;D
( sarcasm ^^^^ )
« Last Edit: September 27, 2010, 08:12:59 AM by grumpy »
Offline Gordon
  • 750K1, 550K2
« Reply #15 on: September 27, 2010, 08:17:43 AM »
I'll start working on a custom set of digital pneumohydraulic float level adjusters for you, stat! ;D ;D
Offline grumpy
« Reply #16 on: September 27, 2010, 08:27:05 AM »
« Reply #17 on: September 27, 2010, 08:32:43 AM »
Per HondaMan, it is for all SOHC4's
KingCustomCycles.com
« Reply #18 on: September 27, 2010, 09:27:52 AM »
I will throw this out there, and have done it to hundreds of carbs. (25+sets :-) I bend the tab to be parallel with the surrounding bracket and leave it at that.  Done, over, runs great. Now someone may ridicule my lack of precision and "devil may care" attitude...........
Offline Gordon
  • 750K1, 550K2
« Reply #19 on: September 27, 2010, 11:12:18 AM »
I think we may have found the reason why so many of us have had to adjust our float levels! :D :D
« Reply #20 on: September 27, 2010, 11:39:10 AM »
Exactly, all that fiddling keeps you guys sharp.  Everybody is somebody elses PO :-)
« Reply #21 on: September 27, 2010, 06:59:33 PM »
I wish quick fuel would make us some carbs. Externally adjustable needle/seat with a glass fuel level window. Maybe I could adapt a 1250 cfm quick fuel 4 barrel with an adapter!
Offline FrankenFrankenstuff
    • FrankenBike Stuff Store
« Reply #22 on: September 27, 2010, 07:07:13 PM »
I always bend the tabs to .04 if I have any issues. I once had a 72 CB450 that the PO had fiddled with so much the fuel would just flow through the carb and fill up the case. He sold it to me thinking it was a major issue....I got it cheap...bent the tab to .04 and then sold the bike for 9 times what I paid.
Offline Stogie1020
« Reply #23 on: September 27, 2010, 07:19:32 PM »
So, I am new to all of this and am reading a few of the carb threads, but having never done any carb adjustments before, is there a book with really good pictures  ;D out there to assist someone like me with adjusting needles, float valves, etc.?
My cb750K8 runs good, but I am going to swap out the PO installed pods for the stock box and know I will need to adjust the carbs.
1978 CB750K
« Reply #24 on: September 28, 2010, 12:35:03 AM »
ide like to see a mini quadrajet for sohc fours.
