Author Topic: Dead starter.  (Read 887 times)
Offline chrisnoel
Dead starter.
« on: September 26, 2010, 06:40:02 PM »
Testing a starter with a 12v 1a charger should work right?
Want to make sure I have a good starter so I hooked up the pos lead to the terminal screw on the stater.  Next I hooked up the neg lead to one of the mounting screws on the starter housing.  A few sparks but the thing didn't even try to spin.
Any one see some problems with this test or is the starter dead for sure?
Re: Dead starter.
« Reply #1 on: September 26, 2010, 07:21:14 PM »
1 amp is next to 0, I would use jumper cables on a vehicle [car/truck] with a known good battery.  And no need to have it running.
« Last Edit: September 26, 2010, 07:46:39 PM by meriggi »
Offline chrisnoel
Re: Dead starter.
« Reply #2 on: September 26, 2010, 07:30:44 PM »
Got it to spin on a car charger set at 2A.  Charger has 10a and 50a available but I'm glad it spun at 2.  Suppose the 1a trickle charger wasn't a bad idea but in hind site it is next to nothing like you said.
